b|b|i Billet Uprights Parts List and Installation
#62
@Ecosse911 I plan on sticking with the 964 control arms and longitudinal. My wheel is exactly where I want it to be....and further, I rebuilt them. So, with it in the car, I plan on pressing, drilling and pressing in the 993 stud for the 993 ball joint.
I'm going to update post #1 with the new plan. Feel free to correct me.
#63
BBI raises the axle 25mm compared to 993RS, 993RS axle appears to be the same height as 993, I didn't measure that just going by the pic here that I took, axle height is normal to the line from A to the shock
a std 993 ti=e rod mounts above the w/c arm, 993RS mounts below
std
RS
for a lowered car a raised axle and/or lowered rod end is what you want, the goal is to get the tie rod and A -arm arcs to be as concentric as possible
std
RS
Pete
#64
While your pic shows that the shock mount is in line with the axle height on both (993 and 993rs) carriers is not the crucial measurement regarding the axle height the length from the ball joint to the axle center? If so that is obviously different between the RS and standard 993 units. It seems to me that there are 3 differences at least- steering arm height, axle height and shock height all relative to the ball joint height.
Pete
Pete
the ball joint is passive wrt to height
the ball joint is pushed up and down by the wheel carrier, it only changes the angle of the A-arm, some shops actually mount the ball joint above the A-arm, this determines the angle of the A-arm wrt to the tie rods and ground
similarly the the geometry of the tie rod itself and any o/s at the tie rod ball joint(if any) determine the angle of the tie rod wrt to the angle of the A-arm and ground, at the inner end the steering rack also has a sya, in pre 1990 911s the steering rack is often spaced down to alter the tie rod angle
The angles of the A-arms determine roll center height, which largely determines cornering characteristics, the differential in A -arm and tie rod outer end arcs determines bump steer characteristics
964 w/ 993RS wheel carriers and o/s ball joint
#65
I'm very late to the game, but my car was purchased with a pretty exhaustive list of upgrades including the BBI Uprights. The listing is here with plenty of pics, but more importantly scanned copies of all the work orders & parts. Not sure if helpful but perhaps?
https://bringatrailer.com/listing/19...1-carrera-2-49
#66
axle height is determined by the strut and springs and the relationship between the 2 bolts that fasten the wheel carrier to the strut,
I’ve seen pics of the ball joint mounted below and above the arm but I can’t wrap my head around how it would change the actual lower control arm angle- as the angle should be measured as a line from the center of the ball joint through the inner control a pivot. Even if the control arm and the ball joint had a 2 “ spacer between it the effective angle hasn’t changed as far as I can tell.
#67
Does anyone have either of these two measurements:
1. 964 vs 993 uprights. The depth and diameter of the abs sensor holes. Or perhaps if easier the sensors themselves.
2. 964/5 vs 993 rotors. The difference in offset.
These two measurements might just solve this rather complex square filter, round housing issue.
#68
#69
Exactly, wondering what that difference is. 5mm?
#70
Are you trying to determine how much it will change the position of your wheel? If so, it will not. Bill is just showing you the offset of the caliper position - so if you're trying to determine caliper/wheel clearance, this makes sense ?
#71
Thank you. Yes I trying to determine caliper placement in relation to my wheel, not wheel moving. As mentioned it is fairly close as it is but I can work with 5mm difference.
#72
It's a great point though, some people are already running really close. What you're looking at there is the difference in offset which will end up being the centerline on the caliper - but does not take into account the actual thickness of the caliper. From centerline, I wonder what the difference is between the stock C2 and big red/turbo caliper face.
Did some measuring on the beater as it has big brakes - looking like @20mm from wheel mount face to face of caliper and 80mm from rotor centerline to caliper face. This is a 964 carrier...and I don't know exactly what these brakes are but likely 964tt. Prob not much help. I'm chowing some lunch but if you want anything else measured I can do it this evening.
#73
Well I’ve ordered the 993T rotors so when they get here I’ll provide the measurements!
I’d think it would even help people with the math in doing any 993 upgrade/swap.
jeff33702 (12-02-2022)
#74
Hi, here's a link to a thread I started when I did this upgrade (but with Porsche 993 uprights). It starts with the parts list and some other things I noted. Finally some comments about the result.
https://rennlist.com/forums/964-foru...ghts-long.html
dmaddox (12-06-2022)
#75
Update - BBi has confirmed the 964 ball join WILL NOT work on their uprights. The 993 ball joint has a different taper and is required. Now...this then requires the larger knurled bolt in the control arm as well.
What remains....The ABS thing (assuming speed sensors, 993-606-405-00). Still researching into this and could really use any help I can get. I can't see if using the same hub bolt/washer/hub why we'd need the 993 version, but I don't know anything about this part or how it affixes to the carrier.
Hopefully, I am measure a 964 ball joint. I was told it was a 964-341-049-03, the hole in it is 0.425".
