Bi-LED Projector Headlight Options
G'day all,
Having just watched a YouTube DIY on installing bi-led projectors in an H4 bucket I was curious to see if anyone was using thses with the original fluted glass lenses and it seems that Rennline st least are offering their H4 bi-led projectors with a classic fluted lens cover option. Does anyone here have real world experience with this combination? All the others I've found have a clear glass cover which to my thinking would be the most effective, but I would like to keep the classic looks of the fluted lens if possible.
Thanks,
Neil
Thanks,
Neil
You might want to look at Audette collection:
Audette Silver™ LED Headlights ~ Low cost, solid quality, Bright Night – Audette Collection ~ Porsche Lighting Restoration & BEST-IN-CLASS Porsche Parts (911bestinclass.com)
They offer you a choice of clear and fluted lenses.
I ordered mine with fluted lenses and I don't think it affects the quality of the light and looks much better
Thanks for the fast reply. That's exactly the info I was after regarding light quality. I was a bit concernecd that the light spread would not be as focused and possibly dazzle oncoming drivers. I'll move forward with the plan of using my original H4 buckets and lenses.
Neil
Neil
I have the Rennlines with the fluted lenses. They look really good, especially since I got the "primer" colored rings painted to match my car. They were a proper pain in the a$$ to install, however. Putting them into the car was the easy part, but assembling them was a lot more difficult for me. IIRC, the instructions say you should install the lights in the buckets, aim them, then put the trim rings over the units while on the car. But fitting the trim rings was so difficult (it took me hours, and what was probably 100s of attempts on the driver's side) that I couldn't do it while on the car, so I'm not sure they're properly aimed - they might be a bit low - but there's no way in hell I'm going to pull them out, aim them, and reinstall!
They look great, though, and make driving at night much much better. Very original looking, although the trained eye will definitely spot the single bottom screw rather than the OG multiple screws and rubber grommets. But this is true of all the aftermarket LED solutions.
How is the light throw and color temperature on these?
I know that the LEDs will put out more total lumens but one of the issues with a lot of these optically suboptimal solutions (like fluted lenses in front of projectors) is that you can get a ton of flood which washes out the road right in front of the car and no throw.
This 'looks' brighter but actually means you can't see as far down the road as you can with a properly adjusted set of H4s.
Would love to see someone do a real beamshot comparison like they do for big flashlights over on candlepower.
I would echo mgordon's comments above. I got the Rennlines for my 2 cars. They were a pain to install and aim. One of those "hope I never have to do it again" jobs. Made me wish I had ponied up the difference for the 9eleven Ravens (I actually like their look, but YMMV).
I don't have the side-by-side pics for comparison. But the Rennlines are a definite improvement over the stock H5s. I can definitely see better at night.
I have the fluted lenses on one car, and clears on the other. I don't think it makes a big difference in light output. I know light guys geek out at how a proper LED system is supposed to be focused and engineered through a non-fluted lens. But maybe the theory doesn't make a big difference in the real world application of this product.
But not a fan of the assembly portion of the product.
I have the Flat6 with fluted lens and I like the look. They're a pain to aim because you need to dissassemble them to gain access to the adjustment screws. Reassembling them takes time and finesse and does get frustratting to get the fitement perfect.
What I did was cut a slot with a hacksaw in the ends of the 3 adjustment bolts and then all you need to do is remove the light assembly from the car to make adjustments.
Pictured is the expected way to make adjustments.
Modified way to make the same adjustments. This shows a disassembled light with reflector, lens and ring removed, but once assembled all you do is remove the light from the bucket and make your adjustments from the backside of the light.
I didn’t order the lights yet, but will the holes create risk for condensation in the lights?
You're right that these light assemblies are open from the back and if moisture is in the light buckets, there is a possiblity of condensation. These lights are waterproof from water coming at them from the front.
Since you already have H4-fittings in your car, you can easily reuse them with LEDs like or
– The only challenges are that they are not street-legal for Porsches (yet) but from what I hear from friends do fit and work plus that they seem to not be available globally.
Personally, I stay with (or ); the most important aspect is to have the modification that leverages a relays to not run all power for the H4 lights through the steering column switch (e.g., https://rennlist.com/forums/964-forum/762224-headlamp-headlight-relays-for-964-a.html); that already makes a huge difference as higher voltage reaches the lights, due to this optimized setup.
rotorheadcase (06-06-2023)
Has anyone bought the offering from Stuttgart Classica?
It looks like they require cutting out the back of the headlight bucket, but the improved look of the recessed projector a la Singer is worth it for me.
https://www.stuttgart-classica.com/b...ed-head-lights
I haven't seen those before, but I do know that the Hella bixenon projectors are well regarded and so LED ones might be pretty decent too.
The install instructions do require cutting out the back of the headlight bucket, they are found here: https://static1.squarespace.com/stat...ht+fitment.pdf
