New valve and timing cover gaskets labor cost
Hey all – my '91 964 developed a small oil leak (maybe 1 drop per day on the floor), so took it in to the local shop. The lower valve and timing covers are both leaking slightly, so going to get both done. I've ordered Rennline upper and lower valve covers with Victor Reinz gaskets, and will use new OEM timing covers. The shop quoted $3500 just to replace both valve and timing cover gaskets, including possibly replacing bank 1 timing chain tensioner. That seemed rather steep to me for replacing the gaskets – is that inline with the expected cost for this job?
Thanks!
Thanks!
I can’t imagine it taking an experienced tech more than 6-8 hours. There is some stuff in the way…
seems high. Are they adjusting your valves in the process? They are quoting you like 3 days labor?
you're in Santa Barbara? You could try calling Marco at tlg, north Hollywood. Not that far from you.
forbiddenbeat (05-18-2023)
Aside from that being an entirely ridiculous cost for that work...
Why bother doing it at all?
You will, at some point, have to do a valve adjustment. If it were me, I'd wait till the valves needed to be done. The valve cover seals get done as part of that job, and the timing chain covers are also more easily accessible at that time, saving time and money on those as well.
Further/ unless oil is pouring out of the motor, you don't have a real problem. And further still, in all likelihood, after you replace those seals, the likelihood of a continued weep (not leak), is very high, negating all the reason why you spent the money and time in the first place .
Soooooo, unless you are crazy, or you find someone to do the work for a crazy low number...just wait a bit and do the seals when you are in there for a real reason.
Yes, I would get quotes to have your valves adjusted, because at least then you have a reason to be in there. Even with that extra labor, it should cost about a third of what you've been quoted, especially if you are supplying new valve covers and gaskets.
Thanks guys. I'm going to ask them to breakout the hours and make sure I'm not missing something. I was indeed going to ask for a valve adjustment since I don't have records of it being done recently.
Edit: actually, looking at the records, valve adjustment was done 3k miles ago (8 years back) and the lower valve covers plus all gaskets were replaced then too. So, indeed, it is leaking again.
Do yourself a favor. You just were handed a quote for a job that was not only priced many multiples higher than the job is worth, but you were also given terrible advice and they attempted to take advantage.
Find a shop that will advise you properly, and charge an appropriate amount, and be honest about it.
It's ok to spend a lot. When it's ok to spend a lot.
The following 2 users liked this post by Goughary:
Hella-Buggin' (05-19-2023),
Turbo Jonny (05-18-2023)
You already stated, that you will use (already ordered) OEM timing chain covers... But just take a look at my post/development here:
https://rennlist.com/forums/964-foru...ngineered.html
Good luck!
Good luck!
Good luck!
Good luck!
But just to confirm, timing and valve covers is roughly a 6-8 hour job? It looks like timing covers require a partial engine drop, which would seem like more than a 1-day job.
Originally Posted by forbiddenbeat;[url=tel:18809581
18809581[/url]]Thanks! I saw your thread – looks like the new ETA is June? Or is that closed now?
Another indie shop I use in town (general German shop) said the quote seems reasonable since the engine has to be partially or fully dropped. Just checking if this is indeed the case.
Thanks. This shop is well-respected in town, so I'm going to call and find out what the breakdown on the quote is.
I think I’s rather put my car on jack stands drop then drag the motor from underneath sit on my but and do the adjustments than give someone that kind of cash.
Remember the saying if if don’t splash when you step on it it ain’t a leak.
