Silly Question
Silly Question
So sorry to waste an entire thread with such a silly question, but couldn't find the answer.
I have converted my C2 to a fixed wing. At speed i get a fault on the dash presumably resulting from the system thinking the wing / motor is still there. What's the easiest way to resolve this?
Or you can jump with a wire in the rear (by the oil filter) assembly...There is a small round assembly (plug) that can be opened to bypass the warning light.
How to defeat warning light when ducktail is installed - Rennlist - Porsche Discussion Forums
Spot number 3 to Spot number 7 Look at post number 13 and 14 for a picture............ This info may be on Pelican Forum as we...
Dumb question of the day
During my last oil change I over filled by a quart. Gage on dash is reading at the top, haven't checked the dip stick to see how high its reading yet.
So, should I be worried and drain some oil out or just let go?
If I drain the the case how much oil would drain?
Any other advice?....
