Maxlite 17 x 9 and 7.5 - fit c4 cab without mods/ spacers?
3rd Gear
Before pulling the trigger..
im looking at a set of the maxlite cup1 wheels, Pelican sells them,
will they fit my 91 c4 cab without rubbing or needing spacers?
car is at stock ride height
thank you!
thank you!
What offsets?
They fit great on my cab
Continental3.2 (07-20-2023)
Fronts can rub on the fender/bumper corner. There’s a service doc describing how to grind off the offending corner- it’s an easy fix. Fronts can also rub inside the wheel well. Service doc recommends steering rack limiters. A search for either will give more info. Rears fit without issue.
I’d recommend going straight to the US distributor- https://shop-us.maxilite-wheels.com/index.php?k=6
