964 Forum 1989-1994
Do you have a 89-91 car w/o head gasket?
Old 05-26-2004, 06:00 AM
Christian K
Christian K's Avatar
Default Do you have a 89-91 car w/o head gasket?
Dear rennlisters
Do you, like me I believe, have a 89-(early)91 car where the head gasket has not been retrofitted?
Any signs of leaks in the head to cylinder area?
What is your milage?
I have 30.500 miles and no visible leaks. There are a oilspot or moisture, but very small and according to my mechanic it's "nothing".
I do not think that I have the gaskets retrofitted, as there are no records of it. On the other hand I have the vent. kit, which must have been put in afterwards, also without any records of that being mounted. Is it possible to see if a gasket has been retrofitted, without opening things up?
cheers
Christian
Old 05-26-2004, 06:07 AM
Andy Roe
Andy Roe's Avatar
I have an early 91 car without head gasket. 61,000miles & not a single leak. Engine is completely dry!
Old 05-26-2004, 08:36 AM
LouZ
LouZ's Avatar
Location: Philly Area ----- George Washington took a dump in my backyard!
Just did a thorough inspection of that area 2 weeks ago, preparing for a DE event and found NO signs of leakage. Car has +79,000 miles on it.
Old 05-26-2004, 08:37 AM
Christer
Christer's Avatar
I had one, but don't know if it leaked from the head. But it did leak though.
Old 05-26-2004, 08:48 AM
alan911sc
alan911sc's Avatar
1990 C4 with 85k no problems.
Old 05-26-2004, 08:49 AM
IanR
IanR's Avatar
Mine's a 90 C2 (built Oct 89) with 105K miles - never re-built and no head leaks, but does have a couple of weeping chest and through-bolt seals
Old 05-26-2004, 08:50 AM
jimq
Burgled
jimq's Avatar
I have 69K miles. previous owner did a reseal on engine but cylinders were not changed. I have no leaks from that area.
Old 05-26-2004, 09:38 AM
DavidI
DavidI's Avatar
1989 'K' series C4 with 120k miles. No gasket and engine is never completely dry, but never seems to actually drip - there's just an oily mist! Reckon I use a quarter of a litre of oil every thousand miles or so.
Old 05-26-2004, 10:30 AM
bb964
bb964's Avatar
I have a ’92 with the factory gaskets, but at about 60K it started leaking anyway. The car was under warranty and Porsche paid for a complete engine reseal. The new gaskets they installed were newer versions of the originals and were of different color.
Bill B
’92 964 Cobalt Blue Met
’03 330xi
’99 E320 4-Matic Wagon
Old 05-26-2004, 10:47 AM
Jay H
Jay H's Avatar
I have a 1990 US spec C2. Built January 1990. No evidence of prior repairs/updates and no leaks from this area with 32,500 miles on the car.
Jay
90 964
Old 05-26-2004, 12:47 PM
Rocket Rob
IHI KING!
Rocket Rob's Avatar
I've not had the problem. I have a '90 C4 with 184K miles on original engine. No overhauls. No leaks at the head/cylinder area. I have had to replace a few oil lines over the years. Currently I have a small drip from the bell housing. The mechanic tells me its the engine main seal. I will repair it whenever I need to do my clutch. In the mean time, I'm tolerating the drip.
Old 05-26-2004, 12:53 PM
joey bagadonuts
joey bagadonuts's Avatar
91 C4 with 85K miles. Heads were machined at 28K miles to eliminate minor drips. No head gaskets and no leaks. Knock on wood.
Old 05-26-2004, 03:18 PM
Arnold
Arnold's Avatar
Angry
90C2 bought at 40k kms and leaked at one cylinder head junction.Rebuilt engine at 151k kms to eliminate oil leaks.No gasket fitted and garage floor still stained by oil????.
Arnold
Old 05-26-2004, 04:32 PM
dumluk
dumluk's Avatar
90 Coupe, 65k miles, heads not leaking. Valve cover gaskets leak, but not the heads.
Old 05-26-2004, 05:43 PM
Rick964
Rick964's Avatar
90 C4 with 40k miles and no leaks, with no work done to prevent or stop any, in that area. Plenty of oil leaks over the years though, but thats a different story.
Quick Reply: Do you have a 89-91 car w/o head gasket?
