Tachometer Stopped Working
My turn signal indicators still work/illuminate. Anything I can check before I pull it out and send it off to see if it can be fixed?
Thanks!
Thanks!
Of course it can be fixed. However, I would check that it gets power supply before proceeding with any repairs.
Working turn signals/high beam bulbs only proves that the GND connection to the instrument is OK.
Is this a tachometer with the OBC option or not?
Cheers,
Tore
Cheers,
Tore
Non-OBC tachos have pin numbers and function printed at the back. Check for ignition switched 12V at Terminal 15, pin 7. GND is pin 2.
Cheers,
Tore
Cheers,
Tore
AFKC (09-21-2023)
I’m having a similar issue on my 1990 C2. The tach is completely dead and stuck at zero - my power windows and power mirrors and windshield wipers also died at the same time. My seats radio lights and signals work. Not sure where to begin, but I think I’m chasing a bad ground somewhere. Wiring diagrams could help me out.
Start with checing the fuses. Then, read post #4 in this thread.
In my opinion, "Check grounds" is the most common time-consuming and misleading fault finding tip on these modern cars.
Cheers,
Tore
Cheers,
Tore
