Yet another soft top issue
Hi friends,
Every time I complain that my soft top fails pretty much once a year, I remember that a coupe would cost $40k more ... and to be fair, it is my daily driver and I operate it probably 1-2 a week all year round which it might not have been designed for.
Anyhow, here's my latest issue: I replaced the driver side latch motor under warranty (little thread on how difficult it was to remove) and while it latches properly, it does not "stop" when the top is fully up (and I hear a tac-tac-tac noise). Additionally the dash light stays on when the top is up. Everything is fine when the top is down.
I tried two things:
Thanks!
I tried two things:
- Top down, I manually pressed both latch micro switch sensors to pretend the top was up and someone else operated the switch: both latch motors behaved perfectly, they would open/close and stop properly. I also checked the latch micro switch sensors and both seem fine and positioned properly
- I tried a semi dangerous operation and kept the left latch micro switch sensor in my hand while closing the top. I fully pressed it when the top was up hoping the latch motor would behave properly and it did not (i.e. it does not stop and goes tac-tac-tac ... and the dash light stays on
Thanks!
Hi friends,
I tried two things:
Thanks!
I tried two things:
Thanks!
Basic Sponsor
Hi friends,
I tried two things:
Thanks!
I tried two things:
Thanks!
Loren
Systems Consulting - Automotive Electronics
Specializing in Porsche cars
http://www.systemsc.com/
Loren
