Seat Belt Buckle Bolt Torque
Technical Guru
Due to a recent cleaning accident involving my passenger side cloth sport seat and an errant carpet beater I've been forced to replace the seat belt receptor 964.803.00.70B - $40.96USD. There is one bolt (see #16 in my hand-drawn sketch) that attaches the receptor/buckle to the seat so before I re-install the seat I would like to make sure the bolt is tightened correctly. If anyone has the torque value for the bolt could they please post it?
Thanks!
Thanks!
Technical Guru
Originally posted by Jeff Curtis
One grunt should do it...I would imagine you'll go bonkers trying to find that value, not sure.
Technical Guru
Originally Posted by Chris M.
Is that somewhere in the factory service manual and I just missed it?
Seat Belt Bolt Cover - Deformed
May 29, 1990
Subject: Seat Belt Bolt Cover, Deformed
Model: 911C2/C4
Group: 6
Part Identifier: 6876
Number: 9004
ATTENTION: Service Manager/Service Technician
Models Affected: 911 Carrera 2 and 911 Carrera 4 Model Year 1989 (K) and 1990 (L)
Concern: Hot air from the engine heats up the right rear seat belt anchor bolt and deforms the plastic bolt cover.
Vehicle Information: A modified anchor bolt cover is installed from production date: August 28, 1989
VIN:
96_LS450081 Coupe
96_LS460062 Targa
Repair Information: The modified bolt cover can be installed in vehicles prior to the above VIN as follows:
Remove bolt cover and bolt (A in Figure).
Install new bolt, bushing and cover (B in Figure).
Torque bolt to 50 N-m (37 ft.lbs.).
Both sides, left and right should be modified.
Parts Information:
New Cover: 964 803 141 00
New Bushing: 999 924 064 02
New Bolt: 803 019 811 B
So 16, 2, and 8 each get torqued to 37 ft lbs? use loctite? thanks!
Seat rail hex/cheese head set screws also high strength, high tensile fixings.
This UK bolt supplier states that most seat belt bolts are indeed 7/16" fine thread but they also mention a rare 11 mm fine thread only available from the dealer.
I am now curious. Jason, if you have not yet installed the bolt can you confirm which one Porsche uses?
https://www.bolts.co.uk/guides-and-t...at-belt-bonds/
Technical Guru
