Rennlist Discussion Forums   classifieds | membership | rennlist | photo album
sponsors | upload photo | chat
Go Back   Rennlist Discussion Forums > Air/Oil Cooled Technical Discussion Areas > 964 Forum
Sign in using an external account
Register Forgot Password?
Thread Tools Search this Thread
Old 10-26-2004, 07:06 AM   #1
Robert Linton
Robert Linton's Avatar
Default Humpty Dumpty Fuel Cell
As there has been interest in the components within Humpty Dumpty, the following description of the approximately 7 kg fuel cell might be of interest.
77-Liter Fuel Cell Including:
a. Carbon Fiber/Kevlar® Enclosure
b. Carbon Fiber/Kevlar® Access Plate
c. Viton® Access Plate Gasket
d. Composite Nut Rings
e. FIA-FT 3.5 Lightweight Bladder With Fuel Baffles, Trap Door And Foam
f. Carbon Fiber/Kevlar® Catch Tank
g. Dual Fuel Lift Pump System [quad system might be installed for certain racing application]
h. Composite Lift Pumps Mounts
i. FIA Three Stage Rollover Valve With Custom Modified Goodridge Machined Aluminum Banjo Fitting For Clearance
j. In-Line 150 Micron Filter
k. Porsche® Fuel Sender Interfacing With Trip Computer
l. Overflow Prevention System
m. Viton® Covered Wiring Harness
n. Titanium Fasteners
o. Carbon Fiber Fuel Cell Mounting Strap And Carbon Fiber/Titanium Clamping System For Front Damper Reservoirs
p. Fuel Filler Neck With Custom Modified Goodridge Machined Aluminum AN Fitting For Goodridge G-Line XF Hose
q. High Pressure Fuel Pump/Primary Fuel Filter Package With Aluminum AN Fittings And Carbon Fiber Mounting [for racing, secondary fuel pump might be installed]
r. Secondary Fuel Filter With Aluminum AN Fittings And Carbon Fiber Mounting
s. Goodridge G-Line XF PTFE Fuel Hoses With Goodridge Machined Aluminum AN Fittings
t. System Connecting Metal Fuel Lines To Goodridge G-Line XF Fuel Hoses Via Machined Aluminum AN Fittings
u. Parker Hannifin –6 Aluminum Quick Disconnects With Chassis Lanyards Between Fuel Lines And Engine
v. All Electrical Connections Through Hermetically Sealed Quick Disconnect Plug
w. Relay Between High Pressure Pump And Fuel Lift Pumps
x. Single Pole, Miniaturized, Thermal Circuit Breakers With Tease-Free, Trip-Free, Snap Action Mechanisms And Push/Pull On/Off Manual Actuations, Temperature Compensated From -55°C To +125°C, For High Pressure Fuel Pump And For Each Fuel Lift Pump
Robert Linton is offline   Reply With Quote
Old 10-26-2004, 08:05 AM   #2
warmfuzzies
warmfuzzies's Avatar
Send a message via Yahoo to warmfuzzies
Robert,
If it hasn't been asked before....why Humpty Dumpty?
Humpty Dumpty in history was an old English Canon.......so how come the name?
If it's been said before, a link will be enough humiliation...............
thanks
Kevin.
http://www.encantada-vacation.com/
Our holiday home from home.
warmfuzzies is offline   Reply With Quote
Old 10-26-2004, 09:05 AM   #3
Christer
Christer's Avatar
one word. awesome.
Christer
90 C2 Coupe - totally not standard and totally not mine anymore
06 BMW 550i M Sport - totally standard
Mk1 GT3 LHD - totally standard
"If you tell the truth, you don't have to remember anything. "
Christer is offline   Reply With Quote
Old 10-26-2004, 09:23 AM   #4
Robert Linton
Humpty Dumpty because it was apart and put back together again.
Old 10-26-2004, 09:34 AM   #5
warmfuzzies
Aha, I see now.
I won't bore you with the rest of the rhyme then.
thanks
Kevin
Old 10-26-2004, 09:37 AM   #6
Christer
Christer's Avatar
where does the wall come into it?
Christer
Old 10-26-2004, 09:57 AM   #7
warmfuzzies
Well it [humpty dumpty] fell off of it...
kevin.
Old 10-26-2004, 11:09 AM   #8
Robert Linton
Too complicated. Nothing to do with a wall.
Old 10-26-2004, 11:20 AM   #9
warmfuzzies
Robert,
Just something that's been bothering me, Carbon fibre as we all see in F1 and GP races tends to disintegrate, or fracture into small shards, it's behaviour is dependant upon the angle of impact as such, does this not make it a poor choice for a fuel cell as compared to plastics which exhibit better deformation without splitting/collapsing....Or is it an impact resistance being greater for carbon fibre issue that swayed you in this direction?
kevin
Old 10-26-2004, 12:06 PM   #10
Robert Linton
Kevin:
That is a problem with carbon fiber. That is why, to quote the above:
Though the Kevlar® adds a bit of weight, it provides the shatter protection.
Bob
Old 10-26-2004, 12:23 PM   #11
warmfuzzies
Thanks Bob, makes sense now.
Kevin
Old 10-28-2004, 12:47 PM   #12
Arjan B.
Super User
Arjan B.'s Avatar
Send a message via MSN to Arjan B.
May be it's bin told, but what are the costs of this project.............??
Arjan B. is offline   Reply With Quote
Old 10-28-2004, 01:10 PM   #13
Robert Linton
With the mold made, the engineering done, other such fuel cells could be sold for approximately $11,000 - $12,000 each -- which, by the way, is on a par with a factory cell for an ALMS/ELMS race car which cells weighs almost twice as much and uses a FT3 bladder. If the FT3.5 bladder in this cell was replaced by an FT3 unit (the requirement in ALMS, ELMS, GrandAm), the cost would be reduced by more than $1000 each. On the other hand, if you added the dry-break system used in ALMS, ELMS and GrandAm, the cost would be increased by approximately $1000. And, yes, for club racing, you can buy cells for many thousand less and, for that purpose, they might, depending upon your needs and wants, be reasonably acceptable.
Old 11-03-2004, 04:56 AM   #14
Arjan B.
Super User
Arjan B.'s Avatar
Thanks, but I ment the costs of the Humpty Dumpty project it self....................
Tags
1796, carbon, cell, cells, fiber, fuel, gline, goodridge, xf
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.5.2
Copyright © 1998 - 2007 Rennlist.com
Advertise on Rennlist - Terms of Service - Privacy Policy - Jobs
Emails & Contact Details
