964 Forum 1989-1994
Door panel removal guide
Old 03-05-2005, 10:00 PM
Marc Shaw
Super Duper Moderator
Marc Shaw's Avatar
Default Door panel removal guide
Required tools
needle nose pliers
5 mm allen key
utility knife
philips screwdriver, medium size (cross-tip)
Pardonmypov (11-26-2021)
Old 03-05-2005, 10:04 PM
Marc Shaw
Marc Shaw's Avatar
Remove upper panel by removing screw from inner small panel and two screws underneath then pop out screw cover on other end (using fingernails) and remove screw underneath.
Old 03-05-2005, 10:05 PM
Marc Shaw
Marc Shaw's Avatar
Unplug power door lock wire and set upper panel aside (plug is keyed so don't worry about labelling it).
Old 03-05-2005, 10:06 PM
Marc Shaw
Marc Shaw's Avatar
Pop manual lock cover off with utility knife, unscrew retaining screw underneath, and unscrew retaining piece (if very tight, use opened tips of needlenose pliers to loosen).
Old 03-05-2005, 10:07 PM
Marc Shaw
Marc Shaw's Avatar
Unhook door latch mechanism by pulling on latch and lifting small bar behind to unsnap out of small, white plastic cup. Unscrew the two bolts behind latch in door handle using 5 mm allen key.
Old 03-05-2005, 10:08 PM
Marc Shaw
Marc Shaw's Avatar
Remove 7 screws around perimeter of lower edge of door to remove door bin. Don't forget screws inside door box that go into door latch region and under the lid at outer edge into door.
Old 03-05-2005, 10:09 PM
Marc Shaw
Marc Shaw's Avatar
Remove 2 bolts from upper edge of door handle using 5 mm allan key.
Old 03-05-2005, 10:10 PM
Marc Shaw
Marc Shaw's Avatar
Unpop door panel by pulling gently on door. There are 3 pop-in nubbins - 2 towards the car and 1 on the outer edge. Unplug power window plug and speaker plugs. Be careful as door still has speaker in it -- it is very heavy and door panel will bend or even break easily.
Pop-in rivets circled in red, plugs to undo circled in green.
Jim Profit (04-14-2021)
Old 08-12-2007, 12:32 PM
Maxx1
Maxx1's Avatar
Thumbs up
Excellent thread.... it was a big help for me too .... thanks
Old 08-12-2007, 10:20 PM
Marc Shaw
Marc Shaw's Avatar
Glad you found it useful.
Marc
Old 08-22-2007, 10:02 PM
Maxx1
Maxx1's Avatar
Smile
Marc
Big time.
I assume the speakers in the door are 5 1/4"
I just bought some MB Quart speakers to install. 6 1/2 looked a bit too big. I am going to take them apart Saturday.
Old 08-23-2007, 12:06 AM
f468357
f468357's Avatar
I just pulled mine apart today and I had ordered Infinity 6 1/2's based on what I had read on here. I can say they don't fit on a '89. Tomorrow I will look for some 5 1/4's that will fit under the factory grills.
Old 08-23-2007, 12:29 AM
deep_uv
RIP
deep_uv's Avatar
Infinity Reference 5010CS 5 1/4" speakers work with the factory grill.
Steve
Old 08-23-2007, 09:01 AM
MisterRisky
MisterRisky's Avatar
Max, I put 6.5" speakers in my doors. Oddly enough the bolt holes lined up, but the plastic "basket" in the door that is behind the speaker managed to rub in a few spots. I was able to "adjust" the basket with a dremel and make it fit just dandy. The speakers I used were Polk Audio.
Old 08-23-2007, 05:37 PM
CraigC
CraigC's Avatar
Very nice write up Marc. Thanks!
Quick Reply: Door panel removal guide
