Rennlist Discussion Forums   classifieds | membership | rennlist | photo album
sponsors | upload photo | chat | marketplace
Go Back   Rennlist Discussion Forums > Air/Oil Cooled Technical Discussion Areas > 964 Forum
Old 08-04-2005, 02:41 PM   #1
JONES199
User
Default Jack Points?
Are there any Jack Points up the middle of the car?
JONES199 is offline   Reply With Quote
Old 08-04-2005, 04:35 PM   #2
garrett376
C4 Specialist
garrett376's Avatar
Middle as in the underside of the engine (midline of the car), or middle as in anterior to the rear tires on the standard jack point?
garrett376 is offline   Reply With Quote
Old 08-04-2005, 05:36 PM   #3
Wachuko
Professor of Pending Projects
Wachuko's Avatar
Send a message via AIM to Wachuko Send a message via Yahoo to Wachuko
Cool
Quote:
I just looked (just to double check...) and there are no jack points in the middle of the car...
Drive Safe!
Jaime Diaz (a.k.a Wachuko)
'83 911 Schieferblaumetallic SC Coupe -> Transformation
'91 964 C4 Wide-Body Cabriolet
'09 BMW X5 xDrive35d
MaxJax low-ceiling two-post lift
Missed but never forgotten:
'02 996TT Seal Gray
'04 VW Golf R32
'97 993 C2S Vesuvius Metallic with Aerokit
'87 951
Rennlist Member 020402-3738
Wachuko is offline   Reply With Quote
Old 08-04-2005, 05:50 PM   #4
garrett376
C4 Specialist
garrett376's Avatar
Jaime - do you use the underside of the engine to jack up the rear?
Old 08-04-2005, 06:22 PM   #5
Jerry Garwick
User
Location: Prather, California: somewhere in the middle of the State
After looking up the procedure for removing the engine and transmission from the 964's I question the wisdom of using the engine for jacking up the car. The engine adapter as pictured in Adrian's book, if one had them, would certainly be of good use.
By the by, has anyone one the list jury-rigged such adapters?
Jerry Garwick is offline   Reply With Quote
Old 08-04-2005, 07:36 PM   #6
garrett376
C4 Specialist
garrett376's Avatar
Quote:
Good point Jerry, but I think it's more for complete removal so you can balance the whole assembly - I've had an engine not so well balanced and it's not a light thing to catch when it decides to topple! Reminds me of a surgeon friend of mine who ended up disabled for a couple months because his engine rolled off the jack onto his hand
I think jacking on the engine shouldn't cause harm, since one of the contact points of that adapter is in the same place as the jack pad would go. I bet if you did a poll most people use the engine to lift from... but I could be wrong!!!
Old 08-04-2005, 08:56 PM   #7
TroyN
TroyN's Avatar
Take a look at: http://p-car.com/diy/jacktowpoint/. I've considered one of these, it looks cool too. Assume it would work for 964 as well.
'87 930:Elephant strut brace,Fabspeed air,K27S,Fabspeed Maxflo,Leask RPM switch,Garretson IC
'99 986(polar silver):UD pulley,solid trans mounts,987 motor mount,GT3 arms
Past P-cars:
'82 911 ('07-'10)
'98 986 ('06)
'96 993 ('02-'08; my first)
TroyN is offline   Reply With Quote
Old 08-04-2005, 10:50 PM   #8
Wachuko
Wachuko's Avatar
Talking
Quote:
I used to... placed a piece of wood to avoid metal to metal contact... ..but there was always that fear that I would break the engine case...
Now I use this:
Drive Safe!
'02 996TT Seal Gray
'04 VW Golf R32
'87 951
Old 08-04-2005, 11:38 PM   #9
jimq
Burgled
jimq's Avatar
Send a message via Yahoo to jimq
Jaime,
I been wanting to ask you how the lift was working out. Now seems like a good time! Looks like pretty good. Any problems? I am really thinking of getting one after i sell the Benz and have another side of the garage to use! If you dont mind what was the cost again and was it hard to set up?
jim
Conservatives....We work hard so you don't have to
91 White C2 Cab tiptronic
03 Black 996TT X-50 Grocery getter
2002 Dodge Ram 5.9L Gas Hog
Bend-Pak Scissor Lift
64 230SL Mercedes (SOLD after 18 years )
Some other Porsche's
jimq is offline   Reply With Quote
Old 08-05-2005, 12:10 AM   #10
Wachuko
Wachuko's Avatar
Cool
Quote:
Originally Posted by jimq
Jaime,
Jim,
If you have the ceiling height to accomodate it, go with the two post unit... not much more that expensive and you will have better acccess to the center of the car. If that is not the case then this unit is a good alternative.
I have been using the unit for any work in the R32 or the 964... heck, I sometimes lift the 964, sit on the sit-on creeper and just stare at the car... sick I know... I also changed the exhaust in my brother's Volvo, a few VW Vortex members that needed help with this or that...
So far it has been working without a problem. Here is the link to the thread with all the information. There was a guy that modified (cut) one cross member to have better access to the engine in his 993. I might do the same since there seems to be no structural risk in taking off that part. Or I just might modify it to be able to take that cross member out and bolted back in when not working on the engine in the 964...
go the last page of this thread... you will see the piece that he removed and there is also links to a video of the lift in action...
Mid-Rise Lift
You are looking at around US$1,500.00 delivered to your house.
Drive Safe!
'02 996TT Seal Gray
'04 VW Golf R32
'87 951
Old 08-05-2005, 12:37 AM   #11
JasonAndreas
Technical Guru
JasonAndreas's Avatar
The one warning I've been given about engine jacking was that it will cause the hydraulic motor mounts to fail forcing the jelly to ooze out. I haven't seen it happen but two mechanics on the east coast have warned me and yet I still do it anyway... (RS motormounts here I come)
JasonAndreas is offline   Reply With Quote
Old 08-06-2005, 07:17 PM   #12
PaulStewart
PaulStewart's Avatar
I like this one since it has adjustable lifting arms, is portable, and is 41.25 inches wide. Keep scrolling down, it's a long page....
http://www.asedeals.com/mid_rise_lift.html
87 924S
01 986
98 986 3.6 liter, 325 hp, 7.8 DME, LSD, Cayman S headers, 996 Instrument Panel, B&B cats and mufflers
Owned and repaired Porsches since 1974
PaulStewart is online now   Reply With Quote
Old 08-06-2005, 08:27 PM   #13
jimq
Burgled
jimq's Avatar
anybody tried one of these lifts? Doesnt look real sturdy but maybe would in person.
Is it the same as you have Jaime?
jim
Old 08-06-2005, 08:28 PM   #14
Marc Shaw
Super Moderator
Marc Shaw's Avatar
Goodness, I would not climb under that.....I'd be afraid.
Marc
1991 964 C4 Coupe - Black/Black not quite stock
All my C4 mods are listed here.
Marc Shaw is offline   Reply With Quote
Old 08-06-2005, 10:38 PM   #15
Wachuko
Wachuko's Avatar
Thumbs up
That is what I have...
Pretty solid... that thing weights close to 1,000 pounds... has a mechanical lock, dual hydraulic arms. If you follow the link to the other post you can see one owner from the 993 forum that use it to raise the car and worked/remove the engine and tranny.
Drive Safe!
'02 996TT Seal Gray
'04 VW Golf R32
'87 951
Tags
150000, 2002, 2500, 325xi, 911, 964, bmw, dodge, engine, jack, jacking, maxjax, point, points, porsche, removed, x5
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
Copyright © 1998 - 2007, Rennlist.com
Advertise on Rennlist - Terms of Service - Privacy Policy - Jobs
