Accurate weight table
We are all interested in weight loss but are missing a complete reference table showing the various components’ weights. There’s plenty of information on Rennlist but it’s all over the place and often wrong.
I've made a start putting it all together: weight in lbs (2.240 lbs to 1 kg) manual narrow C2 Coupe, unless otherwise stated.
Corrections/additions are very welcome. A complete and accurate weight guide should be of great help to all members of this forum.
Curb weight euro (DIN) 3,031 (including all fluids, full gas tank but without any options such as a/c, radio, sunroof etc.)
Hood 42.0
Hood hinges, both 3.7
Front hood struts, each 1.0
Rear deck struts, each 1.0
Rear deck lid 10.0
Moveable rear wing 8.0
Fully motorized rear lid 24.0
Door, each 81.0
RS Door, each 50
Stock door shell, each 38
US Collision bar in door
Door hinges, 4 pairs 1.5
Elect window mechanism 3.0
Flag Mirrors, both 6.7
Teardrop Mirrors, both 4.5
Rear wiper complete 4.5
Sunroof 44.0
Window Glass
Rear Glass
Front seat (comfort, normal) each 52.5
Bucket seat (RS) including mounts, each 30.5
Rear seats, both 15.4
Rear seatbelts, both 4
US 5 mph bumper supports F/R
US rear bumper beam 16.0
RS euro rear bumper beam 11.5
US front bumper beam 13.25
US rear bumper 5.0
US front Bumper
Bumperettes, both 2
Front Fogs, both 4.0
Third brake light 4.0
Cup 1 Wheel set 7, 8 x 17 41.4
Front calliper + pad 12.7
Front rotor 17.0
Rear brake 29.7
Wheel bolts (lug nuts x 20) 4.2
Power steering 22.0
G50/20 gearbox (manual) with LSD 156
Stock con-rods, each 669 – 678 grams
Pistons, each
Crank
Crank pulley and dampener 1,161 grams
Engine casing
Complete exhaust system with CAT 96.0
Primary muffler 22.4
Secondary muffler 22.8
Engine under tray 14.0
Dual mass Flywheel 30.5
Clutch
Under floor soundproofing + carpet 69.4
Carpet + pad 22
Engine insulation 10.0
Trunk carpet + liner 5.6
Front windshield washer tank with pump 12.0
Under seal
Wheel well plastic protectors
Battery 75Ah 46
Aircon + coolant + hoses 47.0
Airbags (driver + pas) 13.0
Tunnel under tray/stiffener 5.0
Heater/blower 6.5
Spare tire + air pump 34.6
Hood 42.0
Rear deck lid 10.0
Door, each 81.0
RS Door, each 50
Sunroof 44.0
Window Glass
Rear Glass
US rear bumper 5.0
US front Bumper
Bumperettes, both 2
Front rotor 17.0
Rear brake 29.7
Power steering 22.0
Pistons, each
Crank
Engine casing
Clutch
Carpet + pad 22
Under seal
Battery 75Ah 46
Heater/blower 6.5
Update
Since you are asking, here's the latest... Weight in lbs unless shown differently.
Bonnet 42.0
Rear deck lid w/o wing 10.0
4WD Tub (tub only, NO doors, hood, fenders, undercoat, paint, seam sealer etc.) 424.0
Tub undercoating + Paint + seam sealer 86.0
Doors, each 81.0
RS Doors, each 50.0
Stock door shell, each 38.0
Skin, each 18.0
Glass 10.0
Elect window mechanism + motor 22.0
Electric window motors (both) 3.0
Rear wiper and motor, complete 4.5
Windshield
Rear Glass
Sunroof 44.0
Door panels with pockets, both 17.0
RS Door panels, both 6.5
Rear shelf 24.0
RS/Cab rear 'luggage dump' 25.0
Airbag steering wheel 9.0
Recaro Pole Position including mounts, each 28.0
Cobra Misano R 23.0
Rear seatbelts, both 4.0
Carpet + pad 22.0
US 5 mph bumper supports F/R (four) 12.0
US front bumper beam 13.3
US rear bumper 5.0
US front Bumper
Bumperettes, both 2.0
Cup 1 OEM Wheel set 7, 8 x 17 100.4
Bilstein PSS9 set approx 65.0
964 Front calliper + pad 12.7
964 Front rotor 17.0
Rear brake 29.7
Front Rotor Protective plates x 2
RS Rotor Protective plates x 2
Uprights x 2
Power steering 22.0
G50/20 gearbox (manual) with LSD 156.0
Tiptronic gearbox 222.0
Stock con-rods, each 669 - 678 grams
Pistons, each
Crank
Engine casing
Alternator Bosch 115 amp 6+
Basic exhaust 30.0
Primary muffler 23.5
Secondary muffler 23.3
Catalytic Converter and shielding 16.0
Total 92.8
Metal tube for pass compartment heat 4.0
LW flywheel 12.3
Clutch
Battery 75Ah 46.0
Wiring harness, w/o fuse panel 55.0
Airbags, harness, sensors (driver + pas) 13.5
Heater/blower 6.5
Full tank of gas (US tank 77 liters, 20 gallons) 116.0
Full tank of gas (Grosse tank, 92 litre) 138.6
Engine oil (15qts) 25.0
Transmission oil 8.0
Aircon fluid
Bonnet 42.0
Doors, each 81.0
RS Doors, each 50.0
Skin, each 18.0
Glass 10.0
Windshield
Rear Glass
Sunroof 44.0
Rear shelf 24.0
Cobra Misano R 23.0
Carpet + pad 22.0
US rear bumper 5.0
US front Bumper
Rear brake 29.7
Uprights x 2
Power steering 22.0
Pistons, each
Crank
Engine casing
Basic exhaust 30.0
Total 92.8
LW flywheel 12.3
Clutch
Battery 75Ah 46.0
Heater/blower 6.5
Aircon fluid
God I feel so fat
or
Dose this wing make my deck lid look fat
or
I sure got moms wide body wheel wells
or
He says it dosen't matter how much I weigh,yea right,did you se how he looked at that Cup Car over there.
or
She 's had so much carbon fiber and fiberglass done I bet not one bit of her body is factory.If she gets hit out there he's in for quite a surprize
A little humer very little....but I dought I'm the only guy car is the other women.
or
or
or
or
Back from the Dead....
Front windshield (glass+rubber seal+rearveiw mirror+ antennae wire+any grime) Weighed in at 22 lbs. Used bathroom scale, preloaded with 10lbs, then 20 lbs (from a weight set) for accuracy, then place windshield on and subtracted the 10 lbs, then subtracted 20lbs, then weighed sheild without preload...all indicate about 22 lbs.
Jaime
Jaime
1 Post
I'd be interested in knowing:
1) Net effect of sunroof vs non-sunroof. The sunroof weight is listed above, but a car without a sunroof has some weight in steel that fills that hole. At least a few pounds...
2) How much does the spare tire weigh alone (sans air pump)?
3) Stereo speakers and in-dash head unit?
4) US spec RS America seats?
5) Roll bar/cage weight?
Hi Greg,
I am 99% sure that 44 lbs is the net savings, not the weight of the panel.
I think the spare tire weighs 33 lbs IIRC
I think a full cage is around 150 lbs depending on steel vs. cro-mo, thickness of tubing and configuration. I think my roll bar is around 70 lbs, so when I put in a cage I am also going to swap roofs for a net gain of around 30 lbs.
Notice on all of this I said, I think, but all should should be pretty close.
Front wings: Steel, approx 17lbs each, 4.2 lbs in carbon.
As to engine weight (previous question)
Engine complete 964 RS 3.6 na 498
Engine complete 964 3.6 na 525
Engine complete 964 3.6 turbo 608
Engine complete 993 3.6 na 511
Engine complete 993 3.6 turbo 591
