Rennlist Discussion Forums   classifieds | membership | rennlist | photo album
sponsors | upload photo | chat
Go Back   Rennlist Discussion Forums > Air/Oil Cooled Technical Discussion Areas > 964 Forum
Sign in using an external account
Register Forgot Password?
Thread Tools Search this Thread
Old 06-19-2007, 02:17 AM   #1
LA964RS
LA964RS's Avatar
Default Strange CCU Issue...Opinions?
I went through and read what threads I could find on this subject and this scenario sounds different than the ones I found.
My buddies '92 had the battery go dead recently...first time ever. Then he had the car kick a CEL. I went over to check it out and I reset the CEL and it didn't go back on when car restarted...but seems like the little fan motor in the CCU was just running....with the ignition off, key out! I'm like what's that noise...and it smelled like...you know that smell before smokes starts coming out of the dash?...Yeah, like that!
Anyway, pulled the battery neg again and let it sit for a bit. Hooked battery back up and no fan running....
So is this the sign that the v.expensive CCU is about to take a sh*t????
All the other functions of the CCU work fine....car is what 15 years old now...how long these units supposed to last?
Thanks.
LA964RS is offline   Reply With Quote
Old 06-19-2007, 04:42 AM   #2
Megatron-UK
User
Megatron-UK's Avatar
Send a message via MSN to Megatron-UK
Doesn't the fan run on for a bit when you switch off anyway? I'm sure I read that on here somewhere...
Megatron-UK is offline   Reply With Quote
Old 06-19-2007, 09:46 AM   #3
John52
User
John52's Avatar
There are a lot of documented problems with the CCU fan. I can only share my experience. Yes, the fan is supposed to stay running for 15 to 30 seconds after the ignition is shut off. However, in my case, it just kept on running until it killed the battery after a few days. All other CCU functions worked fine.
Given the price of a new CCU (big bucks) my mechanic opted to install a simple relay switch between the ignition and the CCU. When the ignition is on, power is provided to the CCU, when ignition off , no power to the unit , so the fan doesn't run.
John52 is offline   Reply With Quote
Old 06-19-2007, 10:06 AM   #4
dfinnegan
dfinnegan's Avatar
That fan will run for up to 20 mins after shutting the car off. Come back after 20 mins and if it's still running then there is a problem.
1991 C4 Coupe, Polar Silver
The hours a Porsche spends parked. You don't get those back.
dfinnegan is offline   Reply With Quote
Old 06-19-2007, 12:12 PM   #5
LA964RS
LA964RS's Avatar
20 minutes! I've had a 964 for 7 years now and its never run that long....wonder if mine is working?
I think my buddy needs the fan issue resolved as I bet that's what drained his battery...
All great info, thanks.
Old 06-19-2007, 05:07 PM   #6
JasonAndreas
Technical Guru
JasonAndreas's Avatar
Quote:
If the fan is staying on for longer than 20 minutes and draining the battery the proper fix is to replace the transistor (T1) BC337 ($0.36USD) on the lower PCB. Unfortunately I don't know of any method to test the transistor without first removing it? Anyone here an EE?
Wick up the solder
Remove the component and clean the PCB with denatured alcohol
and don't use this much solder. and then clean again after its cooled.
I had to temporarily remove the component next to the transistor to place it properly. My only other option was to split the two circuit boards and that involves soldering a bunch of joints versus only two.
JasonAndreas is offline   Reply With Quote
Tags
964, 993, battery, ccu, dead, fan, issue, porsche, stay, swich
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin® Version 3.7.4
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.5.2
Copyright © 1998 - 2007 Rennlist.com
Advertise on Rennlist - Terms of Service - Privacy Policy - Jobs
Emails & Contact Details
