Help with brake upgrade ideas.
Why do you think you need a brake upgrade? Stock brakes (except for the 2 piston rears of the early 964s) are good enough for track use.
I think that for $1500 or less all you could consdier is used calipers from a car with bigger brakes. The one thing you don't want to do is put bigger brakes up front and leave the rears as they are.
Super Duper Moderator
Cheap upgrades:
1. Castrol SRF or other high temp fluid
2. brake cooling ducts/hoses
3. Pagid or equivalent pads
4. new brake lines (ss or rubber)
5. titanium backing plates (?questionable efficacy)
Marc
Marc
To improve braking distance, you'd need to upgrade to larger diameter rotors ie 380mm which will provide more brake torque, especially at high speeds and will slow the car faster. I can tell a difference between my 332x32 fronts and a car with 380x32 endurance brakes using the same pad area and two piece calipers.
A cheaper alternative that many people don't realize is that you can buy new, from the dealer, Big Black calipers from a 928 for about $600 for both calipers (they were about $247 each 2-3 years ago). Add new, factory 965 rotors for $144 a piece, and some caliper adapters ($300 new, 100 used if you can find some) and you've got a Big Brake setup for about half the price of most kits out there. Get some 993 rear calipers and remove the proportioning valve (or use a 60-bar turbo valve) and you'll have a nicely balanced, super braking car. The calipers aren't red, which I actually prefer
Now that's what I'm talking about! What is the best way to go about getting the part numbers for this stuff?
Also didn't mention if he has an RSA w/ the 298s or real RS w/ 322s
Originally Posted by boxsey911
When I got my car (C2) I thought that ditching the 2 pot calipers would be the first thing I'd do. However, I've been seriously impressed with their performance on the track. Am I not trying hard enough?
I replaced them with 4-pots from a 968.
Wow, what a difference! Now, I'm getting better balance F to R, running cooler and getting shorter stops.
Ditto...and a "how to" to go with it!
Originally Posted by LouZ
I was semi-impressed with my 2-pots but I was boiling ATE, losing the pedal and got to the point that I blistered the paint on the front wheels.
That's good info. I think I will still change my 2 pots even though they are performing well at the moment. And of course, 4 pots look so much better . Did you remove the proportioning valve, fit the turbo version or not do anything?
Hi Bill, I was not responding to the post about the brake upgrade, but rather the satement that the stock brakes are good enough. While I agree that it is unlikely that you will get fade with the stock setup which are ceratinly great brakes, you can improve braking distance by increasing the brake torque available ie larger rotors.
