964 Forum 1989-1994
Loud gurgling noise
Old 03-03-2008, 05:42 PM
964Patrick
964Patrick's Avatar
Red face Loud gurgling noise
Hi all,
After a pretty embarrassing oil overfill about two months ago , I'm having some trouble again.
When starting cold, after some 5 seconds loud gurgling noises are coming from the right side rear. Can only be heard from the inside. It sounds like the oil gurgling, but much, MUCH louder than normal. Sometimes the noise is preceded with a metallic-like squeaking sound (Might also be a belt squeak, not sure. Lasts a few seconds). After a few minutes, the gurgling noise goes away.
Something else that caught my attention is that the oil pressure is elevated. Running idle, it doesn't go below 3 bar, which is very unusual.
I don't think the overfill (fixed by my tech) and this problem are related, because it developed later in time. However one never knows, so I thought I should mention it.
After some searching in past posts, I tentatively suspect the oil thermostat. I'm very curious to your opinion / experience. Some pointers on diagnosis would be welcome too.
Any help greatly appreciated. Thanks,
Patrick
Old 03-03-2008, 06:06 PM
Indycam
Indycam's Avatar
What does your oil temp gauge read ?
What oil do you have in the motor ?
Old 03-03-2008, 07:35 PM
altarchsa
altarchsa's Avatar
Before I recently fixed two oil line leaks, my oil level got low and I noticed an oil gurgling sound, same 5 second timing, but mine was coming from what seemed like the rear blower area of the engine compartment. It was definitely an oil circulation noise. Stopped when I put the correct amount of oil in.
Are you sure you have enough oil now?
Old 03-03-2008, 09:11 PM
Meares
Meares's Avatar
i have it as well........but, it's not THAT noticeable; it stops shortly after start.....i figured it was normal.....is it not?
Old 03-04-2008, 03:17 AM
964Patrick
964Patrick's Avatar
I'll take her on a longer drive today, to get everything fully warmed up. Will check for noises, oil temp, oil level, oil pressure and report back here. Thanks for the replies so far.
Old 03-04-2008, 06:17 AM
Duck
Duck's Avatar
I have the same issue lately. I hope it is not anything wrong. I cannot afford any more work on the car for a while.
Old 03-04-2008, 08:15 AM
meek
meek's Avatar
There was a very recent post on this gurgling noise on the 993 forum and the concensus was that it was normal. Tends to happen more when the engine/weather is cold. All part of the oil cooled character.
EDIT - here is the thread https://rennlist.com/forums/993-forum/413120-993-percolating-sound-on-warm-up.html
Old 03-04-2008, 11:16 AM
blitz928
blitz928's Avatar
EDIT - here is the thread https://rennlist.com/forums/showthread.php?t=413120
+1 on that my old 1995 993 did the same thing. Oil traveling to the oil cooler, noise
Old 03-04-2008, 11:50 AM
buellrunner
buellrunner's Avatar
Mines a gurgler too...Always has.
Old 03-04-2008, 11:53 AM
aeroman
Man of Way Too Many Avatars
aeroman's Avatar
The oil gurgling noise is to be expected. It's the tubes in the wheel well.
Old 03-04-2008, 11:55 AM
elbeee964
elbeee964's Avatar
Smile
Startled me when I first drove my '85 Carrera ten years ago...
Now? It's just music to my ears. ( If it were a pet, that'd be a wagging tail, or a purr, in my mind.)
Old 03-04-2008, 12:58 PM
Crystal Cranks
Crystal Cranks's Avatar
No Gurgling would be worse at least it lets you know there is oil in the system. Just another one of the quirks of these cars.
Aeroman your avatar made me laugh.
Old 03-04-2008, 03:36 PM
newsboy
newsboy's Avatar
Got the same gurgling, more when the car sits for a few days, goes away with warm up.
Old 03-04-2008, 06:39 PM
Arrivare
Arrivare's Avatar
Mine is the same as meek's. Very loud in Winter and hardly noticeable in Summer. I changed out the internals of the oil thermostat thinking that it was sticking in cold weather and it made no difference.
Old 03-04-2008, 07:01 PM
colo964
colo964's Avatar
gurgling is normal (very noticable) - at least on mine. just for grins, check your power steering reservoir.
Quick Reply: Loud gurgling noise
