964 Forum 1989-1994
Driver front wheel wobbles +1/8" Can I track the car?
Old 09-06-2008, 10:41 PM
FamilyCar
FamilyCar's Avatar
Default Driver front wheel wobbles +1/8" Can I track the car?
Driver front wheel can be moved left and right about +1/8" probably less than a 1/4" Wheel can't be moved up and down. I don't hear any grinding. Drove car fairly hard a laguna yesterday, felt OK. Can I run the car? Pack the wheel bearings?
Old 09-06-2008, 10:44 PM
deep_uv
RIP
deep_uv's Avatar
IMHO, Not without new bearings.
Old 09-06-2008, 10:47 PM
walterj
walterj's Avatar
Is it in the vertical or horizontal plane? Vertical is a wheel bearing... horizontal is a tie rod and I'd not drive with a sloppy one at all since the whole steering thing is somewhat important
Old 09-06-2008, 10:52 PM
FamilyCar
FamilyCar's Avatar
moves on horizontal axis 1/8-1/4" of play.
sorry, I'm a lousy mechanic. Do those things loosen up further and fail. Other than sloppy handling do a risk creating a catastrophic failure, possible loss of control of the car?
Old 09-06-2008, 10:53 PM
FamilyCar
FamilyCar's Avatar
ie., moves in the way it would if you were turning the steering wheel.
Old 09-06-2008, 10:55 PM
ltc
Super Moderator
Needs More Cowbell
ltc's Avatar
NO
Old 09-06-2008, 10:59 PM
walterj
walterj's Avatar
Originally Posted by ltc
NO
+1
Old 09-06-2008, 11:02 PM
Colin 90 C2
Colin 90 C2's Avatar
sounds like a tie rod end.
pretty easy change out.
make sure to measure the amount of threads when replacing, so to keep your alignment close.
Old 09-06-2008, 11:04 PM
FamilyCar
FamilyCar's Avatar
Did you say something Itc? LOL. Seriously, appreciate the opinion. If play comes from tie rod assembly is that a diy w/ simple tools? Event tomorrow LS
Old 09-06-2008, 11:16 PM
FamilyCar
FamilyCar's Avatar
These pieces circled in red?
Old 09-07-2008, 12:30 AM
wsybert
wsybert's Avatar
No way. Your life is not worth the potential downside of the components letting go. I wouldn't put my car on a track unless it was 100%.
Old 09-07-2008, 01:15 AM
FamilyCar
FamilyCar's Avatar
I need 2 track cars.
Old 09-07-2008, 01:18 AM
Jasko
Jasko's Avatar
Probably part # 3 above - the fork - only part in the assembly with bushings. The rest of the assembly is rigid.
Dave
Old 09-07-2008, 01:28 AM
garrett376
garrett376's Avatar
Devil's advocate - if it's a wobbly bushing in part #3, it's designed so it is unlikely it would come apart - might get more wobbly, but if it's #3 it's not going to separate. I would just make sure you're not looking at something else that's wrong.
How did you notice the problem? What make you investigate?
Old 09-07-2008, 08:54 AM
springer3
springer3's Avatar
True, but not really the point. With lash in the steering, you are running a physics experiment with unknown consequences. Perhaps not likely, but you could encounter an instability that would cause that wheel to flutter. You could lose control of the car in a turn. Stay off the track, and be extremely cautious on road until the steering is fixed. The life you save could be mine.
Quick Reply: Driver front wheel wobbles +1/8" Can I track the car?
