Latest Porsche Tyre Tests
Lifetime Member
Lifetime Member
Hello, in here
Has anyone found the results of the recent Porsche tyre tests as regards the 964? They were meant to be published at porsche.com/classic according to Christophorus, but if so, they are well buried.
Ta.
Ta.
Just read this months article John, I'd say you thought the days of checking the garage floor for oil leaks were gone when your sold your 964. At this rate the 964 block will be considered one of the most leak free.
Hope yours stays dry and keep up the work.
Lifetime Member
Lifetime Member
The Bridgestone RE01r is one of the best street tires. They are almost as quick around a short track then A R Comp. To check out the best tires just go to the SCCA Solo 1 results list for the Topeka championship.
I went searching for that reference chart on the website & couldn't find any tire information anywhere. It was odd, because Porsche made such a big deal about the tire testing they did in the magazine, and I thought it was great, only to be let down by the absence of any information on the website. If anyone finds it (maybe Porsche posted it later?) please send a link here. More out of curiousity, as I still use the tire brand/type that came with my car (Michelins) but I have a cab that sees no track time so I'm not as concerned as some others might be about absoloute tire performance.
Just curious- John if you don't have a 964 why are you asking about 964 tires? Are you thinking of an early Christmas present for yourself? Something to give you a thrill on the weekends when you can take a break from your daily driver GT3?
3 was not as good as it could have been..engine didn't feel revvy which wasn't too bad as the track was damp so full throttle max revs wasn't on the cards much.
Too the car to OPC next day and they've had it since, fault shown as camshaft out of alignment with crank, so engine out and fiddling around. Getting it back later today.
Oulton is quite a track...there's a few scary corners...
Lifetime Member
Lifetime Member
It's all to do with die blauen Schatten.
You should have said hello!
As we've not met before (and still not yet) it wasn't until late in the day that someone pointed you and the 3 out to me as you went out on a session. That was my fourth go at Oulton and I was suprised at how good the C2 was in those conditions. For the most part predictable breakaways and only the one tank slapper when I was a bit too keen at knickerbrook. Mind you I had guidance from the passenger seat from a local who races there, (Marcus Carniel who decided to leave his 964 race car on it's trailer as he decided it was not a good day to test out the new suspension set up). As you say it's a great circuit for some thrilling corners
I have posted the results for all 'classics' here, John .. if you can't get to it PM me.
http://www.porscheclubgb.org/clientF...nded_tyres.pdf
cheers, Maurice
