964 Forum 1989-1994
Exhaust Probs
Old 04-25-2009, 05:49 PM
lunchboxbill
lunchboxbill's Avatar
Default Exhaust Probs
My car has been making a "tinny" noise when warm. It got slightly embarrasing so I took it in this morning only to be told she's blowing a bit. Mechanic reckons something has corroded inside the exhaust that's making the noise.
Nothing detrimental that needs fixing right away, but none the less needs fixing.
Any recommendations for a sports exhaust upgrade?? (No heat exchangers required)
Its a 1991 964 C4
Nothing expensive, the car is for sale after all. But if I can get something good for a decent price then all the better.
Cheers,
Kieran.
Old 04-25-2009, 06:22 PM
mr pg
mr pg's Avatar
There's a number of primary and secondary exhausts on ebay at the moment. Alternatively, you replace the defective one with cup bypass, or G pipe.
Old 04-25-2009, 06:28 PM
Andy Roe
Andy Roe's Avatar
Try the scrappers for a used part, or as mr pg said, just fit a by-pass pipe on the offending silencer.
Old 04-26-2009, 05:31 PM
lunchboxbill
Does anyone have a picture of the underside of a standard 964 and I can point out the part that needs replacing?
Old 04-26-2009, 06:11 PM
Andy Roe
Andy Roe's Avatar
Not the underside of the car, but you should be able to point out which bit it is!
Old 04-27-2009, 02:29 AM
tbennett017
tbennett017's Avatar
Tinny sound: Is there any chance it is one of the heat shields? That can be tacked back together with a weld or two...
I replaced #8 ^^^ with a cup pipe. I love the sound, and it is a lot lighter than the stock muffler.
There are lots of stock exhaust bits available on ebay etc. Don't buy new.
Old 04-27-2009, 03:47 AM
lunchboxbill
i know its not a heat shield as I only have 1 left on (the others came off earlier in the year and are currently in my cellar) and the mechanic checked that and said it was on nice and tight.
From the image above, I think i'm after replacing the final muffler (number 9)
Old 04-27-2009, 03:53 AM
Andy Roe
Andy Roe's Avatar
OK, then it's either a G-Pipe or a second hand one off of ebay or the like!
Old 04-27-2009, 04:29 AM
lunchboxbill
G-Pipe sounds tempting, but have seen a couple of mufflers on ebay for $150 - decisions decisions!
Old 04-27-2009, 04:37 AM
lunchboxbill
ok - i'll probably do some searching on this topic too, but what are the pro's/cons of fitting a g pipe, whilst i'm at it should i bypass ther secondary muffler to, how much will this affect emissions?
Old 04-27-2009, 04:39 AM
mr pg
mr pg's Avatar
Have you ever heard a car with cup bypass and G pipe?! One or other is fine, but both and you won't be getting on with your neighbours.
Old 04-27-2009, 04:42 AM
mr pg
mr pg's Avatar
Keep an eye on this:
http://cgi.ebay.co.uk/G-Pipe-Porsche...1%7C240%3A1318
Old 04-27-2009, 04:44 AM
lunchboxbill
i don't care too much about my neighbours, we might be moving anyway
is the noise without both still legal (in the UK)?
it looks like for £400 i could get both done, or do i just do the g-pipe for now half the price as thats where the problem currently is
Old 04-27-2009, 05:23 AM
Jim Howley
Jim Howley's Avatar
I would just do the G-Pipe, a straight through exhaust is way too loud for normal driving. Try German ebay as well, always well priced parts on there.
Old 04-27-2009, 09:50 AM
dfinnegan
dfinnegan's Avatar
Originally Posted by lunchboxbill
i know its not a heat shield as I only have 1 left on (the others came off earlier in the year and are currently in my cellar) ...
Any chance you would be interested in selling the heat shield/tin bits?
Quick Reply: Exhaust Probs
