DC Rennlist member selling RSA roof?
Hello guys, quite a few months back a DC ,MD rennlist member was selling
parts from a blue (I think) RSA that had caught a curb and wrecked at the track
he had a decent roof for sale ,thought i could't use it but if still available i'd be
interested in speaking with him,please let me know if someone knows who I'm
speaking of or remembers the car,thanks Bert ecrobinson1726@msn.com
The wrecked RSA he had was Red. His subsequent replacement car, which he still has, is Blue. I'm not certain, but I think the Red car is long gone; IIRC a shop bought the totalled shell, and was going to try and rebuild it as a caged race car.
later C2 and subsequent 993's don't have the same rear vents..
What I'm looking for is a late non/sunroof roof skin...thanks Bert
With a panel flanger, rivet dimpler, and structural epoxy, you can fill a sheet metal opening with no welding required. The repair is as strong as a solid roof, and slightly stiffer due to the lap joint. Best of all, there will be no heat distortion, and no annealing (softening) of the steel. The flanger puts a step around the opening exactly the right height for the new panel to fit flush with the new panel. Match-drill four rivet holes and rivet the four corners. Then match-drill rivet holes approximately 1/2 inch apart all the way around the opening. Drill out the temporary rivets, and then dimple both the fill panel and the existing roof using the holes as a guide. The dimples inter-lock the panel, and let the rivets go slightly below the skin surface. Very little filler is needed to be cosmetically perfect.
Glue holds air planes together these days. Use the right stuff, and it is seriously a better repair than welding. Even if you don't trust glue, the steel rivets and the inter-locking dimples are strong enough to exceed the strength and stiffness of the original sunroof opening.
You might have been thinking about mine (bought post-wreck for the engine). It was black, not blue and I still have the non-sunroof roof clip for sale. PM me if interested.
