Rennlist Discussion Forums   classifieds | membership | rennlist | photo album
sponsors | upload photo | chat | marketplace
Go Back   Rennlist Discussion Forums > Air/Oil Cooled Technical Discussion Areas > 964 Forum
Old 07-01-2009, 05:44 PM   #1
dlpalumbo
User
Default Should ISV turn manually??
I've tried cleaning my ISV, but I still have idle problems. A new O2 sensor helped a lot, but the idle still bounces when I depress the clutch.
I took off ISV (again) and tried to rotate the valve. I didn't apply much pressure, but it seemed to be stuck. It was open about 1.5mm.
Is this normal??
Thanks,
Dan
dlpalumbo is offline   Reply With Quote
Old 07-01-2009, 07:15 PM   #2
Steven C.
Steven C.'s Avatar
You should be able to turn it once it is clean. Apply 12v to it and see if it turns. If not it needs to be cleaned with WD40 or carb cleaner and a Qtip.
Steve
02 996C2 daily driver
91 964 turbo...I'm baack!
71 Fiat Vintage Racer it's red too. 4th owner.
68 Alfa GTAM Replica Vintage Racer....what? Ok it's RED.
''Aerodynamics is for people who can't build engines"- Enzo Ferrari
"Back in my day, tires were skinny and the drivers were fat"- Fangio
"I don't have time to read gauges, I'm racing!" M Andretti
www.firebreathingfiats.com
www.corinthianvintagerace.com
[IMG][IMG]
Steven C. is offline   Reply With Quote
Old 07-01-2009, 09:38 PM   #3
1990-964
User
1990-964's Avatar
Is this normal??
Thanks,
Dan
This may be unrelated but I had been recently having idle problems too. In my case the car would not hold an idle reliably with the isv connected. Even when it would idle it would hunt too much. I tried many things, cleaning the isv, swapping it out for a different unit, cleaning the DME connector pins thinking it could be resistance related and none of it worked. When the isv was disconected it would idle fine except when cold so in frustration I hooked up a bypass switch to the isv so I could control it from the cabin as needed. This got me by but I knew there must be a fix. A mechanic that I know who works on my neighbors Porsche's suggested that the throttle body/AFM was dirty and cleaning it would likely cure the problem. With some skepticism I let him do the work and it worked like a charm. It now idles just as it should with a rock steady idle whether the A/C is on or not. All this and I have a LWF and no harmonic dampener with serpentine alternator belt. So if this can get my car running right it may be worth a try. If you do it yourself it is free and only takes about an hour or less.
1990-964 is offline   Reply With Quote
Old 07-01-2009, 11:14 PM   #4
dfinnegan
dfinnegan's Avatar
Note that the ISV valve turns the opposite way that you might think!
When you look into the valve you can see a gap, that gap must close, then the valve moves past and opens on the other side. Others have broken these valves by trying to make push the valve the wrong way.
If you hold the body in your hands as you might a pencil with both palms facing each other and roll it quickly back and forth you should hear the valve clicking as it swings from side to side.
1991 C4 Coupe, Polar Silver
The hours a Porsche spends parked. You don't get those back.
dfinnegan is offline   Reply With Quote
Old 07-02-2009, 09:45 AM   #5
DaveK
DaveK's Avatar
"Bouncing" idle is exactly what mine did when the dist caps were worn.
Dave
'90 964 C4
'02 996 TT
DaveK is offline   Reply With Quote
Old 07-02-2009, 03:33 PM   #6
68CGPlt
68CGPlt's Avatar
I had the same experience as DaveK. Cleaned ISV, replaced O2 all of which helped some, however Dist caps and rotors were the fix.
93 RS America
94 Carrera 4 WB
Previous P-Car Rides:
03 996 C4S
97 993 C4S
87 944S
68CGPlt is online now   Reply With Quote
Old 07-02-2009, 04:24 PM   #7
TR6
TR6's Avatar
I broke my ISV exactly as described above. The only consolation was that I now have a brand new ISV.
Greg H.
1993 Porsche RS America
2002 Spec Miata
1999 BMW Z3M Coupe
1976 Triumph TR6
TR6 is offline   Reply With Quote
Tags
944, 993, clean, isv, o2, porsche, problems
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
Copyright © 1998 - 2007, Rennlist.com
Advertise on Rennlist - Terms of Service - Privacy Policy - Jobs
