Rennlist Discussion Forums   classifieds | membership | rennlist | photo album
sponsors | upload photo | chat | marketplace
Go Back   Rennlist Discussion Forums > Air/Oil Cooled Technical Discussion Areas > 964 Forum
Old 07-08-2009, 01:13 PM   #1
aussie993gt-faux
User
aussie993gt-faux's Avatar
Default 8 snapped head studs - help please??
Hey ppl, will appreciate any advise.
I recently received my 3.6L from Japan. I was stripping this for cleaning prior to install and have found 8 snapped head studs (now this was only out of three heads - the exhaust is still in the way of the fourth so I havent checked there) so there may be several more!
I knew these engines do snap a stud or two over time but at least 8?????
What is wrong, is this indicative of a more serious issue?
The car probably did a lot of idling and stand still in Japan so maybe ran hot?
Anyway is it a big issue. or just a matter of taking heads off maybe skimming and replacing with high tensile studs??
I would really appreciate some advice.
Thanks.
aussie993gt-faux is offline   Reply With Quote
Old 07-08-2009, 01:23 PM   #2
aussie993gt-faux
User
I should add that the snapped studs were both from top and bottom heads ie the dilivar and non-dilivar studs (they are snapped) not pulled.
im hoping theres no cylinder head or piston damage from heat over time...any experiences.. i was just blown away by 8 studs and there will be more!
Old 07-08-2009, 03:34 PM   #3
springer3
springer3's Avatar
Sorry, no clue. But 8 broken studs in just 3 heads? At 4 per head, there are only 12 total. How could the engine even run?
I check my head studs each time I adjust the valves. So far all are tight. Engine is original. It was my understanding that snapped head studs were rare. I suspect that after the first one breaks, the others soon follow, as the neighbors of the broken stud start to carry its load. Perhaps the engine was driven long after the popping noises started, or perhaps it was run after the fan belt broke, and all the damage occured in one event. Any warranty?
1992 White/Tan C2
springer3 is offline   Reply With Quote
Old 07-08-2009, 11:34 PM   #4
aussie993gt-faux
User
No warranty.
The only thing i can do is split this engine open and see if there is any damage.
from an overheat?
I actually have 2 3.6s now as the first one i bought was accident damaged so they replaced it with this one.
Maybe between the two I can sort something out.
This must be the only 3.6 in the world with 8+ snapped head studs...lucky me
Old 07-08-2009, 11:51 PM   #5
Oracle
User
Oracle's Avatar
I know that Japanese cars sit for long periods and the island is very humid, I've been told that Porsche from Japan usually require much more work than from NA.
Anyway, good luck and use this opportunity for a good engine overhaul
Oracle is offline   Reply With Quote
Old 07-09-2009, 05:57 AM   #6
aussie993gt-faux
User
what could the damage to the cylinder head be?
Old 07-09-2009, 06:36 AM   #7
darth
any corrosion on the broken studs? Once the heads are off check for large amounts of carbon buildup which could raise the C/R.
darth is online now   Reply With Quote
Old 07-09-2009, 07:11 AM   #8
aussie993gt-faux
User
darth, yes it seems the divilar coating had worn off that leaving them exposed to corrosion and they snapped.
Im more concerned that this may have occured in 1 overheating event as springer suggested or even if it was a gradual snapping of study heat may have got into the cylinder head and damaged it.
Old 07-09-2009, 07:37 AM   #9
darth
Snapped studs are caused by increased stress on the stud (i.e. due to higher than normal compression)or a weakening of the stud (ie. due to corrosion or fatigue) beyond what the stud is spec'd out to handle. If your concern is a heat issue, you'll find out once the the pistons are removed and you,re able to see the cylinders/piston walls for signs of scouring. Heat will expand the size of the pistons beyond the clearance specified between the piston/cylinder wall and in the worst case a seized engine will occur.
Bill
90C2
Old 07-09-2009, 08:45 AM   #10
springer3
springer3's Avatar
Quote:
Anything from zero to destroyed. Depends on what happened. If the car was driven a lot after the studs got loose, the loose parts hammer each time the cylinder fires. Things can get pretty banged up and the seals can get flame-cut. If the studs broke in a single over-temperature event, the heads could be OK - but get a valve job and new seals sure.
1992 White/Tan C2
Tags
356, 911, 928, 930, broken, clearance, dilivar, head, loose, piston, porsche, pulled, stud, studs, testing
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
Copyright © 1998 - 2007, Rennlist.com
Advertise on Rennlist - Terms of Service - Privacy Policy - Jobs
