Rennlist Discussion Forums   classifieds | membership | rennlist | photo album
sponsors | upload photo | chat | marketplace
Go Back   Rennlist Discussion Forums > Air/Oil Cooled Technical Discussion Areas > 964 Forum
Old 07-21-2009, 03:58 PM   #1
wellcraft290
User
Default Muffler delete
Ok so today at the shop I was speaking to the mechanic about dong the side muffler exhaust delete. He suggested rennspeed. He said both muffler deletes will be too loud unless tracking etc... Any suggestions?
wellcraft290 is offline   Reply With Quote
Old 07-21-2009, 04:38 PM   #2
BlueHeeler
BlueHeeler's Avatar
IMHO Cobalt has one of the best sets up out there considering cost, power, and sound.
http://forums.rennlist.com/rennforum...81-post16.html
Quote:
For a totally different approach and a lot of $$ saved. I went with a simple 100Cell cat replacement and a magnaflow muffler 3" in and out along with G pipe. I replaced the primary and secondary mufflers saving nearly 40 pounds off the rear of the car. Performance was improved tremendously. Dyno charts show 248 RWHP and 237 rwtq. with only a cup air box as the only other mod.The curve is ideal and car pulls very strong. I have seen fabspeed header cars run another 10 hp and torque but that is about it and IMO not worth spending the extra $$ on.
IMO along with almost everyone at the track I come across says it is one of the best sounding 911's of any vintage they have ever heard. It is not quiet but it is not obnoxiously loud either. It does not drone at any RPM range and even under WOT you can hear the exhaust and listen to the radio without having to raise the volume to ridiculous levels. In all I think the cost was around $1200 installed including fabrication of SS piping and mounting.
BlueHeeler is offline   Reply With Quote
Old 07-22-2009, 08:29 AM   #3
mpeters951
mpeters951's Avatar
Alternatively you might reach out to Troy Chapman @ EBS (RL sponsor, no affiliation) for various Dansk bypass parts. Very professional and timely service and hyper-competitive pricing when I'd purchased there.
Dansk parts have fit perfectly w/o any finessing.
Both muffler deletes is/are loud. Precludes sneaking in after a late night boozer with the lads. But, locally here I've been approached dozens of times over the last couple years with envious inquiries from other 911 owners on how I'd achieved the sound. Admittedly a personal issue, but I love the following: OE manifolds > Fabspeed euro pre-muffler > primary BP > secondary BP > tip. Car is more track than street though. Loud ? Yes. To me, good NVH !
I wonder if a high quality SS muffler of appropriate ID couldn't be fab'd into the center of a primary b/p; assuming euro pre-muffler or race cat/primary/secondary for a VERY cost effective performance improved exhaust.
If anyone knows of a suitable non restrictive stainless muffler that could be made to work as an "inserted" replacement section of a primary BP, I'd like hear of such.
mpeters951 is offline   Reply With Quote
Old 07-22-2009, 11:16 AM   #4
wellcraft290
User
Ok my shop called me this morning and said they can do the big exhaust on the side delete with labor etc for $350. Sound good?
Old 07-22-2009, 11:58 AM   #5
HalV
HalV's Avatar
You can get a G pipe for ~$100-$150 used. If you do it yourself, it takes less than 30 minutes to install. I did this a couple weeks ago and the sound is great. It's louder than stock, but not too loud that I'll wake up the neighbors.
'93 C2 Amazon Green
'02 WRX WR Blue
HalV is offline   Reply With Quote
Old 07-22-2009, 12:37 PM   #6
wellcraft290
User
Any brands etc. I found one on craigslist but looked pretty rough. Also you need a new exhaust tip?
Old 07-22-2009, 01:42 PM   #7
jimq
Burgled
jimq's Avatar
Send a message via Yahoo to jimq
Quote:
uses same Tip
jim
Conservatives....We work hard so you don't have to
91 White C2 Cab tiptronic
03 Black 996TT X-50 Grocery getter
2002 Dodge Ram 5.9L Gas Hog
Bend-Pak Scissor Lift
64 230SL Mercedes (SOLD after 18 years )
Some other Porsche's
jimq is offline   Reply With Quote
Old 07-22-2009, 02:34 PM   #8
BDHo
User
how does this compare to the setup of:
cat bypass and keep the primary muffler and loose the secondary muffler?
its my understanding that most good shops in the NE advocate this as the way to be maximium free flow power out of a 964 motor.
BDHo is offline   Reply With Quote
Old 07-22-2009, 02:49 PM   #9
crg53
crg53's Avatar
There are many opinions which way to go i.e. primary bypass with CUP Pipe or secondary bypass with G-pipe. One sounds slightly different than the other, but it seems that there is one point on which all agree and that is, the primary muffler is the most restrictive of the two.
Steen
PCA 2007
91 C2 Coupe Polar Silver, Factory LSD, Heated Sports Seats, RS LWF, RS Short Shift, Bilstein HD/H&R Sport, GHL cat bypass, Dansk primary bypass, Steve W. Chip.
Previously owned Cars: 1956 DKW coupe 3=6, 1958 NSU Prinz II, 1960 Fiat 500, 1965 Mini Cooper S 1275
crg53 is offline   Reply With Quote
Old 07-22-2009, 02:56 PM   #10
wellcraft290
User
primary is the one on the rear bumper?
Old 07-22-2009, 04:41 PM   #11
crg53
crg53's Avatar
That is correct, heat exchangers to cat to primary to secondary.
Steen
PCA 2007
Old 07-22-2009, 04:47 PM   #12
wellcraft290
User
so your saying do the primary first or do the secondary if only doing one
Old 07-22-2009, 05:07 PM   #13
crg53
crg53's Avatar
I have a cat bypass and a primary bypass (Cup pipe) on my car, I kept the secondary muffler, it has a nice mellow sound not too loud.If you bypass both mufflers it gets way too loud. I would recommend you do one or the other, but not both, the choice of which muffler you bypass is up to you, like I said in my first post, there are many different opinions on that subject, and the only real difference is the cost of the G-pipe vs. the Cup pipe, the latter being the more expensive.
Steen
PCA 2007
Old 07-22-2009, 05:31 PM   #14
wellcraft290
User
i want to keep the cat for inspection purposes
Old 07-22-2009, 05:49 PM   #15
wellcraft290
User
I think I found a g-pipe from a member for a good price. No name on the pipe he bought used but too loud for him. Even offered to help me install how can I go wrong with that.
Tags
944, 964, car, cobalt, cooper, cup, delete, dodge, exhaust, forum, mini, muffler, ram, replacement, rwhp, secondary, wrx
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
Copyright © 1998 - 2007, Rennlist.com
Advertise on Rennlist - Terms of Service - Privacy Policy - Jobs
