Rennlist Discussion Forums   classifieds | membership | rennlist | photo album
sponsors | upload photo | chat | marketplace
Go Back   Rennlist Discussion Forums > Air/Oil Cooled Technical Discussion Areas > 964 Forum
Old 08-11-2009, 01:58 PM   #1
porsche965
User
Default Climate Control Unit for 964
Hi,
I am wondering could anyone help me with an issue i have regarding my climate control unit for a Porsche 964 (1990 Carrera 4) which for some reason has stopped working in my car, i have checked to see if the unit is still working by pugging it into a friend of mines 993 and it works perfectly, therfore i can only assume that there is some other underlying problem. I have also tried bypassing the relay to see will the unit work and is it the relay that is at fault, but this has not solved my problem either, as the unit does not work either when this procedure is done, i have also checked fuses?
i would be greatful if anyone out there has any suggestions on what else i could check for to help me get the unit working again?
New Member
Ireland
porsche965 is offline   Reply With Quote
Tags
964, climate, control, porsche, unit
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
Copyright © 1998 - 2007, Rennlist.com
Advertise on Rennlist - Terms of Service - Privacy Policy - Jobs
