Rennlist Discussion Forums   classifieds | membership | rennlist | photo album
sponsors | upload photo | chat | marketplace
Go Back   Rennlist Discussion Forums > Air/Oil Cooled Technical Discussion Areas > 964 Forum
Old 09-13-2009, 01:43 PM   #1
code7rpd
Default C4 Question: how many have changed the brake accumulator?
Out of curiosity - how many have changed the C4 accumlator ball out as preventative maintenance or due to problems? I read that they hold nitrogen pressure which is slowly lost over time. Considering it is not too exepnsive of a part, would it be worth replacing on a car that has about a 150k on the clock? My pump runs for about 60 seconds on start up after sitting overnight after a full brake bleed (brake lines, accumulator, and drive block). Reading the posts here it seems that some pumps run longer and others for less time so I was curious if anyone changed this part out and got a dramatic improvement in how long the pump cycles.
code7rpd is offline   Reply With Quote
Old 09-13-2009, 01:59 PM   #2
DaveK
DaveK's Avatar
Mine was changed in an attempt to solve ABS problems - probably about 7 years ago now. The pump did run less for a short time afterwards, but that didn't last long.
Unless you know you've got a fault, I'd leave it alone.
Dave
'90 964 C4
'02 996 TT
DaveK is offline   Reply With Quote
Old 09-13-2009, 03:45 PM   #3
John D.
John D.'s Avatar
Over 120K on our '89 C4 - and nope..? I'm in Dave's camp on this... If it's working - I'd leave it alone.
John
'95 993 C4
'89 964 C4 (<- Jen's...)
'68 911 L (<- Jen's...)
Don't Panic - it's just me, John D.(<- Jen's...) posting as me....
Team Geek & Sunday Driver for “Hey, Wait For Me Racing”
Giving new meaning to the term “Frozen Rotors”
John D. is offline   Reply With Quote
Old 09-13-2009, 08:45 PM   #4
DAVISRILEY
Moderator
DAVISRILEY's Avatar
I replaced mine in a misguided attempt to fix a soft pedal issue at 98k. Did not need it, and made no difference. Try flushing everything out properly, with a hammer. Probably will have a shorter pump run time, I know I did.
1991 C4-Guards Freaking Red
Have now fallen off the slippery cliff, no end to the modifications in sight.....
1972 911-Umm, never mind. Rust is pain.
1994 Celica-Ugliest car I have ever owned. Finished the 24 Hours of Lemons at Nelson Ledges. Yee-haw!
1982 LeCar-Next Lemons car. I think there was some drinking involved in this decision.
DAVISRILEY is offline   Reply With Quote
Old 09-14-2009, 02:17 AM   #5
roadsleeper
User
I changed mine because it was holding around 40% of what optimum pressure should be (don't remember what that number is anymore). I know I'm preaching to the converted here, but guys, even if you don't track your cars, bear in mind that how well the braking system holds up could save your butt. My car is an '89 and I have changed the accumulator as well as the brake booster pump because the parts are just plain old.
roadsleeper is offline   Reply With Quote
Old 09-14-2009, 03:12 AM   #6
code7rpd
All good points - does a special tester have to be used for checking the pressure?
Old 09-14-2009, 08:28 AM   #7
Rocket Rob
Rocket Rob's Avatar
My C4 has its original accumulator. I did change the ABS boost pump about 12 years ago when a faulty relay burned out the pump.
Rob
'90 C-4 Cab (daily driver-230K miles on original engine)
'91 C-2 Coupe (weekend toy/DE car)
'91 Honda Civic Si (winter-mobile)
Rocket Rob is offline   Reply With Quote
Tags
1995, 993, abs, accumulator, bleed, bleeding, brake, c4, cars, florida, honda, mark, porsche, pump, repair
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
Copyright © 1998 - 2007, Rennlist.com
Advertise on Rennlist - Terms of Service - Privacy Policy - Jobs
