Rennlist Discussion Forums   classifieds | membership | rennlist | photo album
sponsors | upload photo | chat | marketplace
Go Back   Rennlist Discussion Forums > Air/Oil Cooled Technical Discussion Areas > 964 Forum
Old 11-04-2009, 10:46 PM   #1
RNR247
User
RNR247's Avatar
Default What do code 41 and 34 mean?
Hello,
I own a 1991 Carerra4 with erratic idle problem. The car runs strong when warm, but exhibits slight lean throttle hesitation when engine is cold. The control unit is logging code 41 and code 34. My question is could one of these codes directly affect the idle? On a separate note, 15K mile service and valve job was completed recently.
Any info is greatly appreciated.
RNR247 is offline   Reply With Quote
Old 11-05-2009, 12:11 AM   #2
jimq
Burgled
jimq's Avatar
Send a message via Yahoo to jimq
we need pictures of the car so we can figure out what is wrong.
oh yea welcome
jim
Conservatives....We work hard so you don't have to
91 White C2 Cab tiptronic
03 Black 996TT X-50 Grocery getter
2002 Dodge Ram 5.9L Gas Hog
Bend-Pak Scissor Lift
64 230SL Mercedes (SOLD after 18 years )
Some other Porsche's
jimq is offline   Reply With Quote
Old 11-05-2009, 04:37 AM   #3
mojorizing
mojorizing's Avatar
code 41 = ecu faulty
code 34 = hall signal
Try clearing codes, driving some, then reread to validate codes.
'91 C2 Targa Tip
Quote:
Local cops and I have an understanding. I have them outarmed and they have me outnumbered.
SidViscous
mojorizing is offline   Reply With Quote
Old 11-05-2009, 12:10 PM   #4
RNR247
User
RNR247's Avatar
Hi Mojorizing,
I'll clear codes and validate once again. If codes don't go away, which is your prime suspect that is affecting the idle? And would you replace the ECU and/or distributor unit? Thx!
Old 11-05-2009, 02:30 PM   #5
mojorizing
mojorizing's Avatar
Check the condition of the dual dist. by pulling the connector off of each ign. power pack (coil). Engine should run equally well on either.
Realize that the O2 sensor is out of the loop for the first 30-45 seconds while the engine is warming up. Is this the only time you have rough idle?
Possible bad spark plug wires? Check for arcing while looking at engine bay at night.
I would think that those 2 codes are more of a symptom, than the cause of your idle problem.
What code scanner are you using?
'91 C2 Targa Tip
SidViscous
Old 11-05-2009, 05:05 PM   #6
RNR247
User
RNR247's Avatar
The rougn idle actually starts after 20-30 seconds. Prior to that it idles at around 900 rpm. During rough idle it would drop about 300-500 rpms and then come back up again. When engine is warm, it idles perfectly. We've checked everything already and we're down to these codes as suspect to idle problem.
BTW, is the ECU the same as DME?
I believe my buddy's code scanner is a Hammer.
Old 11-05-2009, 05:24 PM   #7
mojorizing
mojorizing's Avatar
DME=ECU
Re-read codes and if hall sensor comes up again, go from there. Could there be magnetic debris/dust on the head of the sensor?
'91 C2 Targa Tip
SidViscous
Old 11-05-2009, 06:17 PM   #8
RNR247
User
RNR247's Avatar
I'll check for debris on the head of the sensor otherwise I think I may have to replace dual distributor unit then if that doesn't solve it replace DME.
How technical is it to replace DME? In your opinion, is it a good DYI job?
Thanks.
Old 11-05-2009, 11:00 PM   #9
mojorizing
mojorizing's Avatar
The DME is definitely DIY
http://forums.rennlist.com/rennforum...placement.html Follow the steps that are pertinent.
'91 C2 Targa Tip
SidViscous
Old 11-06-2009, 12:06 AM   #10
RNR247
User
RNR247's Avatar
Mahalo Brah! Thanks for the useful info. Now I just have to find a rebuilt DME on-line to replace my faulty ECU (code 41). I think I saw one in the internet for $600 rebuilt.
But first I have to focus on the hall sensor issue. I may end-up replacing the dual distributor. Motormeister is offering a rebuilt Bosch (w/vent kit) for $400.
Tags
34, 41, code, dodge, html
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.2.0
Copyright © 1998 - 2007, Rennlist.com
Advertise on Rennlist - Terms of Service - Privacy Policy - Jobs
