964 Forum 1989-1994
A quick helping hint with the heating!
Old 11-12-2009, 05:24 PM
Polman
Polman's Avatar
Default A quick helping hint with the heating!
When at full cold setting, I get cold air at driver side and heated air at passenger side….
When at full heat setting, I get heat at both sides….
When closing both doors, I hear the typical metallic sound from the heater flaps at the rear so those seams to be okay.
I have checked both relays, and they are moving when I go from cold-hot back and fourth….
-Any hints on what to attack
Old 11-12-2009, 05:50 PM
ilko
Agent Orange
ilko's Avatar
Go after the Norwegians first! Then declare war on the Danes. Leave the Finns out of it.
Old 11-12-2009, 06:04 PM
jimq
Burgled
jimq's Avatar
sounds like a selanoid on the fllapper isnt working. I just replaced both of mine.
Old 11-12-2009, 07:04 PM
foxford
foxford's Avatar
When I had a similar failure, the servo motors were moving O.K., but the "splined" shaft coming out of the motor's housing had stripped. This allowed the arm which pushes/pulls on the flap linkage to move from it's fixed position. My guess, your passenger side "actuator arm" has slipped around the servo's driven shaft.
Old 11-12-2009, 11:09 PM
crg53
crg53's Avatar
We (the Danes) have been at war with the Swedes since year 1012.
Old 11-13-2009, 04:48 AM
Polman
Polman's Avatar
-Okay...I will check the splines on the shaft tonight. Jimq...what do you mean with "selanoid on the fllapper"...I´m a little lost here....
And Ilko...have you been Drinking in the garage again,. or sniffing exhaust fumes…...
Old 11-15-2009, 04:18 PM
Rocket Rob
IHI KING!
Rocket Rob's Avatar
Sounds like you should check your servos (or solenoid) and make sure they are moving as they should.
http://porsche964.co.uk/technical/servos.htm
Quick Reply: A quick helping hint with the heating!
