964 Forum 1989-1994
How to Remove Rear Bumper Face
Old 01-13-2012, 01:39 AM
  #31
Vandit
Vandit's Avatar
So I removed the impact beam tonight. It was really easy, just 1 10MM allen head bolt on each side and it came right off.
I was doing some research on the forums last night and was looking over NineMeister Kermit build thread and how they assembled and reinstalled the rear bumper on that car.
They put together the assembly (cover + impact bar) then installed it as a unit on the car, not separately.
I'll likely used this approach for reassembly. I am also planning on adding the RS center while I have the bumper off the car.
Old 06-29-2014, 05:57 PM
  #32
davidwilson11
davidwilson11's Avatar
Mines getting done this week, got the rs rear section to put on.
Do you need the heat shield? Mine looks rotten!
Old 06-08-2017, 02:53 PM
  #33
Derek911
Derek911's Avatar
Bringing this thread back to life like Dr Frankenstein.
I have removed my bumper cover to add the fvd left exhaust cut out and to have the entire bumper painted. There was no need for me to remove the entire bumper beam.
The debate in this thread seems to be whether the cover is riveted to the beam. Some say it is, some say it isn't. Clearly there are rivets in the parts diagram and for sale on Pelican. In my case the cover was riveted to the beam. The cover is riveted to the support piece (32) by 5 rivets, and the support piece is riveted to the bumper beam by 4 rivets. If you pull the bumper cover off you will break the cover where the 5 rivets go through it. Not a big deal because they are close to the edge and doesn't do much damage. My cover broke since the rivets where in place. I decided, like someone else in the thread mentioned, is to drill 4 new holes in the support piece and use some type of sheet metal screws instead of rivets so that in the future I can just unscrew them.
Without some type of fasteners under the center tail light section, the bumper cover will just be held on by the screws in the wheel well and the two brackets at the bottom. That doesn't seem sufficient to me. I'm sure the rivets were installed for additional support and to stop movement or vibration.
In my case... The bumper cover was held on by the screws/bolts in each wheel well, two screws in the two middle brackets (13), and the 5 rivets under the center tail light (which may or may not be fastened based on if the bumper was removed in the past)
Originally Posted by joey bagadonuts
Correct.
Old 06-09-2017, 12:47 AM
  #34
Earlydays
Earlydays's Avatar
I drilled out the 5 rivets, but did not replace them when I re-attached the bumper cover and it is solidly in place.....
Old 06-09-2017, 11:27 PM
  #35
greg1990964
greg1990964's Avatar
Hey Derek, Interested in selling your bumper cover corner you removed? I am trying to to the reverse you're doing. Bring mine back to stock singe outlet.
Old 06-10-2017, 01:38 PM
  #36
Derek911
Derek911's Avatar
Greg, I am going to keep mine for the same reason you want it. I did see a few used covers on eBay.
Old 01-20-2020, 12:11 AM
  #37
964Luftballoon
964Luftballoon's Avatar
Originally Posted by ducnine
Here is a How To on Removing the Rear Bumper Face.
This might be a long shot that you’re still active on the forum. But if you are. Would it be possible to repost the pictures. It looks like photobucket no longer hosts it or it just needs to be renewed. The process seems straight forward from what I can but but I can’t quite make out the notes. Thanks!
Old 01-20-2020, 06:35 AM
  #38
Navaros911
Navaros911's Avatar
All pics load on my end... so I don't think a repost will do anything.
You sure it's not a daily number of views type of limitation?
Old 01-20-2020, 08:56 AM
  #39
964Lovac
964Lovac's Avatar
This photobucket thing has been the bane of my existence while I go through older threads for DIYs etc.
Almost worse than not having them at all as you can just make out what the photos show (what you need)
964Luftballoon (01-20-2020)
Old 01-20-2020, 03:15 PM
  #40
Matt Andrews
Matt Andrews's Avatar
agree. I imagine its easy enough to figure out. But I need to do this as well. Would be nice if the pictures were refreshed...
Old 01-20-2020, 03:58 PM
  #41
964Luftballoon
That's odd. I've tried on different days, cleared my cache, logged out of acct, logged in, and I still get that watermark and blurred image. If it loads on your end do you mind resharing here for those of us that can't see it? That would be awesome!
Old 01-21-2020, 02:36 AM
  #42
Navaros911
Navaros911's Avatar
Strange, but yes, no problem doing that tonight when I get home from the office.
964Luftballoon (01-21-2020)
Old 01-21-2020, 08:50 AM
  #43
spartansix
spartansix's Avatar
I use this photobucket "fix" that works pretty well- it's a Firefox extension, but I'm sure there are equivalents for other browsers:
https://addons.mozilla.org/en-US/fir...-embedded-fix/
Old 01-21-2020, 10:12 AM
  #44
cobalt
cobalt's Avatar
Received 1,928 Likes on 1,167 Posts
FYI if you are going from the US rear center bumper section to the ROW or ROW RS center section you will need to remove the plastic impact parts attached to the aluminum subframe and remove and relocate the tow hook insert.
Old 01-21-2020, 02:09 PM
  #45
Navaros911
Navaros911's Avatar
Here you go, pics from the original post... quality is low, but hey, it was a long time ago.
The pictures looked OK on my phone, but as soon as I look at them on the PC, it is clear they are not clear at all...
Quick Reply: How to Remove Rear Bumper Face
