964 Forum 1989-1994
Horn Connection with Aftermarket Steering Wheel
Old 01-29-2011, 08:13 AM
sml
sml's Avatar
Default Horn Connection with Aftermarket Steering Wheel
I am not sure how to connect the wires with this aftermarket OMP steering wheel.
In the photos, you can see how I connected it up. I tried contacting the blue wire connector onto the hub but that didn't seem to help.
Any tips?
Old 01-29-2011, 09:39 AM
anto1150
anto1150's Avatar
it has to be "grounded" to the hub
Old 01-29-2011, 09:45 AM
anto1150
anto1150's Avatar
BDW, I do not understand why are you mounting that steering-wheel like that...!? How come U did't use a central horn button? You must be a cable-lover or something... how can U screw-up the steering-wheel with those cables...?
Old 01-29-2011, 09:54 AM
sml
sml's Avatar
I tried touching the round metal connector of those two blue wires to the metal hub and also tried the central nut. Maybe the metal hub is covered in paint which explains why that doesnt work .. but even touching the metal lock nut did not seem to work.
Could there be a problem with the other wire connection? or something else?
Old 01-29-2011, 09:56 AM
sml
sml's Avatar
Not sure ... ask Porsche that selected the components for the 997 GT3 RSR .. same wheel.
Old 01-29-2011, 04:49 PM
sml
sml's Avatar
Are there any locations where I could ground that blue wire just for testing?
During testing, the ignition was turned to the position where the dash lights are illuminated.
Old 01-29-2011, 08:59 PM
sml
sml's Avatar
Bump ... would be great to get this sorted today whilst the horns & steering wheel are apart ... in about 10 hrs, I'll need to put it back together ready for the drive to work tomorrow.
Old 01-30-2011, 03:57 AM
anto1150
anto1150's Avatar
looks a different situation to me....
try to short-contact the black cable to the hub: if it works, than it's buttons issue; if it dousn't, it could be a fuse or the horns.
Old 01-30-2011, 07:50 AM
sml
sml's Avatar
thanks ... gave it a shot but it did not work
previously the horn worked (the high tone horn anyway) before I ...
a) pulled out both horns to repair the low tone horn and I tried resoldering the joints, and they are now both re-installed.
b) replaced the steering wheel & have not much idea about connecting it back up.
so i tried touching the connection onto the spline nut, hub and different combinations with both wires but nothing seemed to work.
probably a simple job for an auto electrician so i might have to drop it off soon
Old 01-30-2011, 10:09 AM
chfs911
chfs911's Avatar
Try this thread for info
https://rennlist.com/forums/993-foru...-wiring-2.html
Old 02-01-2011, 08:28 AM
martin964
martin964's Avatar
also make sure that the copper piece on the back of the hub (which connects the hub to the steering column on a circular track) is bent out far enough to actually touch the circular track... they are not usually adjusted correctly (I have had to bend both the one I fitted in different cars).
if that is touching, it will probably work when you connect the blue wire to the hub..
Old 02-01-2011, 08:32 AM
sml
sml's Avatar
thanks guys.
looks like I will be pulling off the hub again in the next few days
will keep the thread updated. fingers crossed.
Old 02-01-2011, 10:07 AM
anto1150
anto1150's Avatar
are you saying you didn't install the sliding contact???
Old 02-01-2011, 04:28 PM
sml
sml's Avatar
I'm not sure to be honest.
I only just recall pulling off the old hub, sliding on the new hub.
Hopefully I wasn't meant to salvage some parts from the old hub ... I just dropped the whole lot on ebay and it is long gone. This is what was sold on ebay .. should I have kept any of these parts? ...
Old 02-03-2011, 08:16 AM
martin964
martin964's Avatar
you are not missing anything (well you shouldnt be..) the new hub should have a copper tab exactly like the one on the back of your OE wheel. just make sure it is bent out enough to touch the contact on the steering column and therefore complete the circuit.
Quick Reply: Horn Connection with Aftermarket Steering Wheel
