Welding Secondary/Final Muffler
I've seen several threads where the final muffler has failed - especially where there has been a primary bypass / cup pipe.
Well, I have now joined that group!
But I haven't seen the results of any successful repairs...
I guess the simplest thing to do is weld up the cracks & then maybe weld a patch on top. Has anyone done this / has it worked?
Hello Vic,
mine went similarly (I have a cup pipe). I bought a second hand silencer from douglas valley, and my split silencer is currently with a friend for welding up. I think several other guys on here have had this done with good results
cheers
martin
cheers
martin
My secondary muffler also split. I noticed it as I was putting on a primary bypass pipe, so it split with a completely stock exhaust system. I just had it welded at the local muffler shop, but mine had only split along the seam. Not sure how long it will last. Muffler guy suggested I find a new one ($$). He was also surprised by how thin the metal was.
Would if not be more cost effective to replace the final with a G pipe then pull the cup pipe and reinstall the original muffler? Sound should be similar. Redline HP gains would be replaced by low end torque. Just a thought.
Yep, I would have done that, but unfortunately I sold the Primary Muffler some time ago
I have a spare primary if you'd like it, but it's in the US...
Also I'd disagree with Laker, (respectfully) but the sounds are very different from the two setups. I agree that the torque increase is true, but I prefer the cup pipe setup for the different sound.
Here's how my cracked...
How is the sound different? I'm going to put the primary muffler back on an run a G pipe in an effort to get the sound to 88 db for Lime Rock Park. I'll run both mufflers if I have to. BTW 90db measured at the track with the cup pipe and secondary muffler.
A secondary bypass has a more gruff, woof-woof sound (sorry I know that's a horrible description...check U-toob for videos). Sounds more like a Subaru flat six. That said, it still sounds good...
I'll let the track guys give you the final answer, but based on reading past threads and my parking lot observations, I think bypassing the primary (using a G-pipe) is louder.
Yep, the G-pipe is louder. I've tried both and the primary by-pass is a much nicer sound in my opinion. Each to their own though!
(Hi Udo! You not coming to Paris this year then?!)
