Hot running problem
Hot running problem
Hi everyone,
I could use some troubleshooting guidance....
Problem:
When the car is cold or warm, the engine runs perfectly. But when the engine temperature gets to full 'hot' (above the "8-o'clock' line on the temp gauage), the engine begins to run poorly. The engine misfires; is low on power; and the idle is unstable (nearly stalls when clutch is engaged). And it sounds like a VW microbus!
Initial troubleshooting findings:
1. Checked CEL for fault codes - none.
2. From researching the archives, I thought that it may a failing engine temperature sensor. However, I tested the temp sensor resistance at the DME control unit, and it was right within specifications at both cold and hot engine temps. So it appears to be functioning correctly.
3. No visible arcing from ignition wires or coil when misted with water.
Any other troubleshooting ideas would be greatly appreciated!
Thanks as always.
Problem:
Thanks as always.
Check the codes first - there's a procedure to do this and (from memory) I think it's - press the accelerator pedal all the way down to WOT, put key in ignition, turn to the 'on' position (not fully on, you don't want the engine to fire), when the CEL light flashes let off the accelerator pedal and then read the code denoted by the flashing lights.
I had a serious misfire that was related to an intermittent injector valve fault on the cylinder one that behaved similarly. Up here in the NW it could just be that the injector electrical clip has developed some corrosion.
Good luck - let us know what you find!
Probably old... maybe even original. Does it matter that I don't want this to be the problem? They are expensive and time consuming to replace!
Anyway, in all seriousness... do you think that engine temp might really trigger a problem with the wires?
Thanks.
Thanks.
dunno, suppose as the wires expand due to heat, some cracks could also expand allowing an arc.
Mist it and find out. Easy enough to do. Would also swap the DME relay with your spare, just to rule that out.
yeah, it was the 1251 code if memory serves - intermittent injector valve fault on cylinder 1.
You know, this could be a flaky ISV too - you might try unplugging the ISV after warmup when the idle stumble begins - if the issue is the ISV having a problem post-warmup, then the problem will go away when you unplug it. Just an FYI though, unplugging the ISV with the car running will cause the CEL to light until it's reconnected so be aware of that. I've done this procedure and it was a great way to diagnose a dirty ISV.
