964 Forum 1989-1994
NGK Spark Plug Wires
Old 07-13-2011, 08:13 PM
Shamus964
Shamus964's Avatar
Default NGK Spark Plug Wires
Just wanted to share some info on what I feel is a ripping good deal on wires for anyone who needs them. I recently replaced my factory originals with a set of NGK's and was very pleased with them.
First the good - These wires can be had on the bay for $159 a set right now - I may buy another set as a reserve at that price. Also, these wires have the Porsche correct 'Beru' connectors on them (the 'porsche' moniker is sanded off but they're clearly marked Beru), and the wires have the proper Beru crimping to avoid issues down the road. They're the same diameter as the OEM wires so they fit into all of the looms and spacers correctly, and the lengths were spot-on. When comparing them, I found that the NGK wires (shielding, composition) met or exceeded the specs of the OEM's.
The downside of these is:They aren't marked numerically for the cylinders so one has to mark them using the OEM set's lengths as a guide. There's another thread that contains this info and it was excellent to have. They also don't come with the various spacers and looms attached already so upon installation you have to swap over these pieces to the NGKs from the stock wires.
The installation was straightforward (though doing wires on these cars is always a pain) and I would estimate that removing the ends to run through the grommets, and swapping the looms and spacers over to to the NGK's added a little time (like 30 minutes) to the install, but I choose to run most of the wires sans ends anyway to avoid having to remove the A/C pump and to ease the fishing of the wires to the right side upper cylinders.
Anyway - thought that this info might be helpful for folks that don't want to spend over $400 for a set of plug wires. I spoke with the seller prior to purchasing these (to verify the Beru ends) and his comment to me was that when they're gone, they're gone.
BTW the OEM wire lengths are (thanks to dfinnegan):
1-1 8.75"
1-2 15.75"
1-3 20.50"
1-4 40.75"
1-5 42.00"
1-6 42.25"
2-1 21.00"
2-2 26.125"
2-3 30.25"
2-4 47.00"
2-5 46.50"
2-6 51.625"
coil-1 21.125"
coil-2 20.75"
- Shamus
Old 07-13-2011, 08:55 PM
Babalouie
Babalouie's Avatar
Thanks, I'm going to do the same job in the next weekend or two.
For the bottom row of plugs, do you have to remove the cat or secondary muffler?
Old 07-13-2011, 09:01 PM
RSAErick
RSAErick's Avatar
Interesting. Thanks for the option. I'm assuming that these must be them....
http://cgi.ebay.com/ebaymotors/NGK-E...Q5fAccessories
Old 07-13-2011, 09:19 PM
TR6
TR6's Avatar
Wow. Great find. I paid something like $600 for my set...
Old 07-13-2011, 09:27 PM
Babalouie
Babalouie's Avatar
I got these from Pelican: http://www.pelicanparts.com/cgi-bin/...%20non%2Dturbo
They're Beru wires, but without the end connectors (so you unscrew the oem ones and recycle them on these wires). Will report back on how the install goes...
Old 07-13-2011, 10:23 PM
mike9186
mike9186's Avatar
I just picked up a set. Thanks! When I did a valve adjustment last fall I noticed my wires were oil soaked and completely degraded.
As always I am trying to keep my ownership costs reasonable and I've been trying to rationalize buying $500 wires for the past 7 months.
Old 07-13-2011, 11:58 PM
Shamus964
Shamus964's Avatar
RSAErick - yep that was them - there's a number on the auction that you can call to see if he's got more. I chatted with him pre-purchase and he seemed to be a good seller. I got them very quickly but that's probably since he's in Riverside CA and I'm just north in OR.
Hope that helps!
Old 07-14-2011, 02:41 AM
RSAErick
RSAErick's Avatar
Interesting.... the information says that the wires are only compatible with 89 - 91 964's; and not compatible with my car. Hmmm, I thought that the wires were the same for all 964's.
Old 07-14-2011, 03:05 AM
Shamus964
Shamus964's Avatar
That is weird - only one set is designated by Beru for all non-turbo 964's so if a set works for one year it should work for all.
Old 07-14-2011, 11:06 AM
Cosmos99
Cosmos99's Avatar
I bought the NGK's almost a year ago and did the job myself. Time consuming without knowing the lengths off hand but I am completely happy with the end results. I highly recommend them.
Old 07-14-2011, 06:48 PM
Shamus964
Shamus964's Avatar
Seller reposted these on the bay - says he has 4 available. P/N is EUC030 which brings them up via search.
Special thanks to Cosmo99 - you're the reason I took the plunge on these and I appreciated your feedback prior to my purchase!
Old 07-14-2011, 07:35 PM
FeralComprehension
FeralComprehension's Avatar
Thanks for the tip, Shamus.
FWIW, Rock Auto has the best price on plugs at the moment ($2.69 each).
Old 07-14-2011, 07:37 PM
SuperUser
SuperUser's Avatar
Cool, I just go a set:-)
Thanks to all.
Old 07-14-2011, 07:41 PM
Crystal Cranks
Crystal Cranks's Avatar
I would jump on a set of these but the seller does not ship to Ireland.
Old 07-14-2011, 07:53 PM
SuperUser
SuperUser's Avatar
I can ship them to you if you want.
Quick Reply: NGK Spark Plug Wires
