964 Forum 1989-1994
Yet another valve adjustment thread (dial indicator method)
Old 01-03-2012, 07:42 AM
  #31
jody stowitts
jody stowitts's Avatar
Smile
Oh, the glorious feeling of Victory and reaching another milestone!
Old 01-03-2012, 07:43 AM
  #32
jody stowitts
P.S., CHEERS!
Old 01-03-2012, 09:36 AM
  #33
bmohr
bmohr's Avatar
great documentation and pics of the various tools involved with the valve procedure. Thanks RicardoD!
Old 01-03-2012, 10:52 AM
  #34
jody stowitts
Ricardo, there is a very interesting article by Doug Riley over on Pelican website that explains the "Backside" method of 911 valve adjustment. If you hit the Tech articles section for 911's and scroll down to the engine section you'll find it. I don't know if it appertains to 964's or only the older 911's, but to my limited valve adjustment experience (356's) the mathematical theory should(?) apply the same. If you've got some spare time to locate and read the article I think you'll find it very interesting. Apologizing in advance if its old news to you. CHEERS.
Old 01-03-2012, 12:55 PM
  #35
jcs_911
jcs_911's Avatar
Great write and info, even for someone who has done the valve adjustments in the past! More info is always good.
Old 01-06-2012, 09:21 AM
  #36
koenig_roland
koenig_roland's Avatar
Hi,
great thread.
Could you please post some measurements of the Z-Block (length/width) here.?
Thx
Old 01-06-2012, 10:03 AM
  #37
dfinnegan
dfinnegan's Avatar
Default Z-Block
It's roughly 45mm tall, 40mm wide and 20mm thick.
The top and bottom are 30mm wide and 15mm tall.
The upright is 20mm thick.
The holes are 10mm and 10.5mm with the larger being the valve cover stud hole and the smaller the dial indicator hole with the set screw.
Note that the device would function better if the stud hole were a slot as some of the valve cover studs do not align correctly for the given hole centers. As I recall there are two valves that can not be checked via this device, though I've forgotten which ones.
Old 01-06-2012, 11:01 AM
  #38
koenig_roland
THX!!!
Old 01-06-2012, 11:02 AM
  #39
crg53
crg53's Avatar
Here is a print I found a while back.
Old 01-06-2012, 02:57 PM
  #40
RicardoD
RicardoD's Avatar
A definite yes on the slot for the Z-block. The upper valves do not align perfectly. There is another approach as well that I want to try next time with dial indicator swivel clamps and rods. I think that would allow for a huge range of adjustment. But sometimes more adjustment is worse. Slotting the Z block is the way to go. I am going to look into having that done to mine.
Old 01-06-2012, 10:41 PM
  #41
PNine64
PNine64's Avatar
Congrats on getting this squared away Ricardo. I keep flip flopping on attempting this in the spring. I'm pretty sure I'm going to go for it now. Great DIY.
Old 01-06-2012, 10:52 PM
  #42
SuperUser
SuperUser's Avatar
I am about to do my valve job also, this will be the first valve job I have done in 20years:-)
Thanks for the write up!
Old 01-07-2012, 12:42 AM
  #43
DWS964
DWS964's Avatar
I just completed the valve adjustment and plug change on my 93 C4. This is the second time I have adjusted the valves on this car (previous time about 16K miles ago). On the first job I used a combination of the small feeler gauge at the valve stem, the NineMeister Tool, and the "backside method" to build confidence and practice. I especially like the "backside method" from the Pelican post, because you can check the existing gap quite easily before making any changes. Using this method, I found that 8 valves were Good, one was Tight, 3 were Loose. On those requiring adjustment, I used the NineMeister Tool, and in one or two attempts brought the valve back into spec per the "backside method" check. For the backside method, I used 0.0030" as the "loose" spec and 0.0025" as the "tight" spec. The engine is a bit quieter, and seems smoother - but it may be my imagination.
Next project - same task on the 90 C4, perhaps this weekend. My wife will be SO confused to see another black Porsche scattered all over the garage, again, still.
Old 01-07-2012, 12:58 AM
  #44
RicardoD
RicardoD's Avatar
Finally read the backside method article which is here:
http://www.pelicanparts.com/techarti...alveadjust.htm
I love the go and no-go aspects of this approach. Where did you get your feeler gauges? I want to try this next time which may be soon as I am closing in on a 91 C2 Tip purchase in need of the 60k maintenance including a valve adjustment.
I see at McMaster Carr you can buy a 12" long loose feeler gauges for very little in the sizes specified, there is also the gauge sets that are connected at one end. Any recommendations on which to get? Loose may be better I think.
Old 01-07-2012, 03:31 AM
  #45
B. Elliott
B. Elliott's Avatar
I see the one's your talking about. I would definitely get the loose ones. Constantly shifting between gauges on the connected ones can get a bit tiresome. That and it gives you a bit more room to work with... less bulky.
Quick Reply: Yet another valve adjustment thread (dial indicator method)
