964 Forum 1989-1994
Brake job going down the slippery slope
Old 11-29-2011, 09:55 PM
PChar
PChar's Avatar
Default Brake job going down the slippery slope
Good evening all,...
A couple of weekends ago I decided to initiate a simple brake job:
Pads / resurface rotors / rebuilt caliper
After removing the brake lines, the calipers and the rotors, I quickly realized that this job would take more than I bargan for. The hard lines were completely seized and the end of the soft lines were all corroded. I have order several new parts from PP and from Porsche as well. What I though would be a simple walk in the park is starting to look like a Winter long project.
Here how it all started,...
Old 11-29-2011, 09:57 PM
PChar
PChar's Avatar
After removing everything I thought could use new parts, I was left with this,...
Old 11-29-2011, 10:09 PM
RicardoD
RicardoD's Avatar
Sounds like you are doing the right thing. Any problems so far?
For what its worth you have my moral support!
Old 11-29-2011, 10:10 PM
PChar
PChar's Avatar
So, at this point what I have managed to accomplish is the caliper rebuilt with the kit, wash and strip, and repaint.
While the A-arm were out I also took advantage to remove the old bushing and put the Walrod set, fairely easy job if you have a torch.
Old 11-29-2011, 10:59 PM
FeralComprehension
FeralComprehension's Avatar
Full rehab- nice!
Old 11-29-2011, 11:08 PM
Babalouie
Babalouie's Avatar
A brake job that turns into a suspension rebuild, is the very definition of slippery-slope
Old 11-29-2011, 11:29 PM
PChar
PChar's Avatar
Any suggestion of suspension mods,... should I replace with same type struts and springs?
I do about 8-10 autocross sessions every year, other than that it's street driving on the weekends with the Miss'.
Old 11-30-2011, 01:04 AM
Marc Shaw
Super Duper Moderator
Marc Shaw's Avatar
Yup - my hard lines were seized up solid too so I had to replace them too....gotta love 20 year old parts, eh?
What colour are the calipers to be - please tell me it is not that violet colour on the box!
Marc
Old 11-30-2011, 01:06 AM
tbennett017
tbennett017's Avatar
I KNOW.. I was looking at the photo above, and it took me a minute to grok that your suspension components were.. um ... missing. You dive in deep amigo! Props to you!
Old 11-30-2011, 02:17 AM
90_C2_Cab
90_C2_Cab's Avatar
Stephane,
I just sent you the $$$ for the Cup 1's via Paypal so now you have money to pay for all of this stuff!
Dan
Old 11-30-2011, 08:34 AM
jimq
Burgled
jimq's Avatar
I found the easiest way to get the rubber brake lines off was to cut them so they could
freely turn as you crank on the nuts.
Old 11-30-2011, 11:37 AM
PChar
PChar's Avatar
Originally Posted by 90_C2_Cab
Stephane,
Dan
Thanks Dan, it will be put to good use. I have a set of OZ ultra lightweight wheels on order. Should arrive next week.
Jim, did the same,... after turning the nut from the hard line, and seeing the line twisting, I just used a pair of wire cutter to get it over with.
Calipers are done,.. in RED not mauve,... , all I need is the OEM Porsche high temp decals which I ordered from Suncoast. I have tried the stencil, and the white paint I used did not adhere to the red of the caliper. Came right off when I peeled the stencil off.
Old 11-30-2011, 01:09 PM
Gus
Gus's Avatar
Stephane -
Been down the same road you are going - lot of effort but well worth it -
What are you doing to the rear - make sure you check your boot =carefully as they tend to crack on the inner fold whih makes the crack hard to see.
See - https://rennlist.com/forums/964-forum/665884-suspension-options-for-early-build-964-a.html
Let me know how you like the OZ's as I am looking to go that route.
Old 11-30-2011, 03:18 PM
PChar
PChar's Avatar
Originally Posted by Gus
Stephane -
See - https://rennlist.com/forums/showthread.php?t=665884
Thanks Gus for the advice. I have already removed all of the suspension bits front and back and still looking for a viable and reasonably priced option.
1) Bilstein HD = $1100
2) H&R Coilover = $1800
3) KW V1 coilover = $2200
4) KW V3 coilover = $2700
5) PSS10 coilover = $2950
Option 1,2,3 doesn't offer adjustability but are priced better than 4 and 5.
Since I was planning on buying another 964 just for Autocross/track to toy around, I may just abandon that idea and put all of my budjet into a nice sorted out street/track car,.,..
What do you all think,.. I am always affraid that if I go down the compromise road I will always do thing half way,..
Old 11-30-2011, 04:30 PM
Laker
Laker's Avatar
Zero in on two choices.
IMHO pick 1 or 4. What can you afford right now? #4 will be better all around except price.
Great thread btw
Quick Reply: Brake job going down the slippery slope
