Part Question re: Spring Plates
Are the bushings available for the spring plates (#7) separately or must you purchase the entire part? I have only seen the expensive OEM and aftermarket options.
Very interesting- thank you for the reply! Polyoxymethylene is also known as Acetal and/or Delrin (in the 'States at least...) and can be a very good choice for bushings.
Quoting a BASF white paper: "Polyoxymethylene is an engineering thermoplastic used in applications that require outstanding performance. It provides excellent resistance to fuels and chemicals, low swelling, good long-term thermal stability and good electric insulation capacity."
1 Post
Pelican Parts currently lists a price for part number 96433106010 as $947 U.S. Looks like that part includes the bushing. No current listing that I can find just for the bushing. Might be worth a phone call to someone at Pelican or other parts houses to see if this bushing is offered separately.
