964 Forum 1989-1994
993 calipers and adapters - mounting torque?
Old 03-01-2013, 03:39 AM
alexjc4
alexjc4's Avatar
Originally Posted by s4magman
Sounds reasonable and more in line with with I was guessing. Where did you get this number from?
63ft lb = 85 nm
Old 03-01-2013, 03:47 AM
alexjc4
alexjc4's Avatar
Originally Posted by Don Nguyen
Interesting. Care to share the info/input that he provided you?
I can't comment on the OP's information, but if you are interested in brake bias I made some charts for various combinations of front and rear brake setups here : https://rennlist.com/forums/964-foru...-needed-2.html
Old 03-01-2013, 07:38 AM
s4magman
s4magman's Avatar
Originally Posted by alexjc4
63ft lb = 85 nm
LOL - devil in the details. 85Nm it is, time for me to stop worrying and just set the torque wrench
Old 03-02-2013, 06:00 AM
964russ
964russ's Avatar
Ive been running this brake set up for over a year, no need to change master cylinder.
Works fine.
Old 03-02-2013, 11:43 AM
s4magman
s4magman's Avatar
So, when I approached Dan Jacobs to see what he recommended I do to get rid of the track day heat problem with my stock calipers (Castrol SRF solved most of the boiling issues) and my wish to upgrade to Big Reds he recommended I try 993 calipers for the front and removing the pro portioning valve. Dan told me this was a very common solution for track cars and that it works very well on the 964. He said it would be perfectly fine to keep the 964 4-pot rear calipers and that this would allow me to skip updating the master cylinder. He did not claim this type of upgrade is better than big reds or a full 993 system but that I would be happy with this set up.
Old 03-05-2013, 04:16 PM
s4magman
s4magman's Avatar
Ok - Rennline has confirmed that their adapters are designed to use the standard torque numbers - 85Nm.
Quick Reply: 993 calipers and adapters - mounting torque?
