964 Forum 1989-1994
Yet another brake pad replacement DIY
Old 05-05-2013, 01:27 AM
RicardoD
RicardoD's Avatar
Default Yet another brake pad replacement DIY
Hi Guys,
I used various sources to figure out how to change the front brake pads on my 1991 C2 tip today. This would be the same for a C4 on all 4 corners and same for all 4 corners on post 1991 C2s. Anyway here is my DIY in photos.
kos11-12 (08-14-2022)
Old 05-05-2013, 09:58 AM
cobracarrera
cobracarrera's Avatar
Thanks for posting this...I am about to tackle the rear brakes on my 1990 C2....
Well written with great pictures to help the step by step process...
Old 05-05-2013, 10:27 AM
kos11-12
kos11-12's Avatar
Thanks for the pictures & write up !
Did you fit new mushrooms
Old 05-05-2013, 10:34 AM
Laker
Laker's Avatar
Nice Job Ricardo
Old 05-05-2013, 11:06 AM
c didy
c didy's Avatar
Stellar!
Old 05-05-2013, 12:36 PM
LM964
LM964's Avatar
+1 for any DIY steps and pics...
Old 05-05-2013, 02:12 PM
RicardoD
RicardoD's Avatar
I reused the mushroom pads
Old 05-05-2013, 02:14 PM
RicardoD
RicardoD's Avatar
Cobracarrera, the rears on the 90 & 92 C2s are different. I just ordered brake pads for the rear and will document that as well.
Old 05-05-2013, 05:34 PM
Marc Shaw
Super Duper Moderator
Marc Shaw's Avatar
Be careful pushing the pistons back in - you don't want to tear the rubber gasket around them.
Also, watch the level in your brake fluid reservoir as the level will go up as you push the pistons back in and fluid back into the system - overflowed brake fluid can be kind of messy and harmful to painted surfaces.
Great write-up!
Marc
Old 05-05-2013, 10:40 PM
rstarga
rstarga's Avatar
I prefer to push the piston in with the old pads, shoving a screwdriver in is asking for trouble.
Old 05-05-2013, 10:48 PM
jcs_911
jcs_911's Avatar
I use the rubber coated handles of a pair of Channellock pliers. Or equivalent. The 2 handles allow you to push both pistons back at the same time.
Old 05-05-2013, 11:30 PM
RicardoD
RicardoD's Avatar
I'd love to have one of these in my tool chest.
Lisle 29100 Quick Quad Pad Spreader : Amazon.com : Automotive Lisle 29100 Quick Quad Pad Spreader : Amazon.com : Automotive
ZDMak MK-BRK-J looks like it would work to:
http://zdmak.com/wbstore/main.asp?ac...K-BRK-J&CTMP=1
Old 05-06-2013, 03:09 AM
Marc Shaw
Marc Shaw's Avatar
I have one of these and it is the best. From here.
Marc
Old 05-06-2013, 07:03 AM
Harry Apps
Harry Apps's Avatar
Great write-up but the photo's don't show the correct assembly. Both pads should be connected to the wear sensor and the sensor cable secured with a spring clip to the pad retaining clip. See PET (Front Brakes) items 18 and 22.
Old 05-07-2013, 05:21 PM
cobracarrera
Looking forward to it...
Thanks again...At least it gives some sort of guidance..
Quick Reply: Yet another brake pad replacement DIY
