Engine drop, reseal, and refurbish completed!
Thank you Rennlist!
I joined about 10 years ago and its been so much fun to hang out with you guys and share my passion for 964s.
I just completed my 1990 Carrera 2 tip engine drop, repair, and reseal and could not have done it without the tremendous help of the hard core rennlisters who keep contributing.
I finally got the engine back in and went for a shakedown run and the engine response was incredible and so smooth. I bought this car, drove it to get registered and immediately started tearing it down when I got it back in my garage. That was about a year ago. Once I get the car registered again I will be ready to use it as my daily driver.
List of items off the top of my head
Alternator rebuild
New caps & rotors
New spark plug wires
New spark plugs
Distributor drive belt change & shaft seal
Distributor vent kit installed
Front & rear brake lines
Front & rear brake pads and wear sensors
Oil filter & change
Fuel filter
New trans filter, seals, and gaskets
Transmission fluid flush
New air filter
Fuel injectors removed & refurbished at witchunter
Power steering pump rebuilt & new drive belt & camshaft seal
New oil temp sensor & oil pressure sensor gasket installed
New breather vent gasket
New deckled and new front trunk shocks
New chain tensioner and oil bridge gaskets
New ignition coils
New engine insulation pad installed
New firing order sticker
New shell lubricants sticker
Complete brake system fluid flush
New crankshaft seal
All new belts
A/C bracket modified for easy removal
New crankshaft seal
New engine mounts
Replaced failed transmission mount
Powder coat tins and valve covers
Valve adjustment
Alternator rebuild
New caps & rotors
New spark plugs
Oil filter & change
Fuel filter
New air filter
New ignition coils
New crankshaft seal
All new belts
New crankshaft seal
New engine mounts
Valve adjustment
Great work Ricardo
Two extra points:
1. You have now earned a new badge to put on that sweatshirt.
2. We now know that you're an Abba fan.
Two extra points:
Good to hear Ricardo! I know its been a long road traveled for you, great to hear you will be driving the tip as you intended....11K miles on mine in less then 9 months....I would say I'm liking her
Now it's time for some everyday Porsche magic... enjoy your daily drives!
