964 Forum 1989-1994
Alternator parts number - help
Old 10-24-2013, 11:16 PM
bo11
bo11's Avatar
Default Alternator parts number - help
I need to replace bearing of my alternator. my car is convertible 964 year 1993.
I find a good source for repair kit :
http://www.aspwholesale.com/index.ph...1015&Submit=Go
BUT they ask me the Bosch alternator part number. i cannot provide because i did not remove the alternator yet.
I assume the alternator is original.
I find on internet several numbers
0 120 468 029
0 120 468 125
Can someone help me and confirm which should be the correct part number?
Chris
Old 10-24-2013, 11:47 PM
joey bagadonuts
joey bagadonuts's Avatar
Part number from Porsche 964 Katalog: 964 603 156 01
But I have seen other derivations: 964 604 156 AX
Here's a write up from Pelican if you haven' seen it already:
http://forums.pelicanparts.com/porsc...r-rebuild.html
Old 10-25-2013, 04:02 AM
911PERVY
911PERVY's Avatar
He wants the Bosch number:
0120468125
Old 10-25-2013, 01:38 PM
JasonAndreas
Technical Guru
JasonAndreas's Avatar
Originally Posted by bo11I find a good source for repair kit :
[url
http://www.aspwholesale.com/index.ph...1015&Submit=Go[/url]
That "kit" uses the el'cheapo POS chinese voltage regulators. The VR you want is #928.603.142.00 available for about $50 from a Porsche dealer (try sunset imports). Or from any Bosch supplier as #1.197.311.040 for a bit less.
The X at the end of a Porsche part number denotes a remanufactured part.
Old 10-26-2013, 01:35 PM
joey bagadonuts
Old 10-28-2013, 10:53 AM
bo11
bo11's Avatar
thanks you very much for your answers. indeed i needed the bosh part number.
011Pervy gave me 0120468125
and from pelican it is 0 120 468 029
Pervy you confirm that the number is for late modele 964?
Chris
Old 10-28-2013, 11:02 AM
Steve Weiner-Rennsport Systems
RL Technical Advisor
Steve Weiner-Rennsport Systems's Avatar
Jason,......that VR is now $245. It certainly still a good buy if its not made in China.
Old 10-28-2013, 01:43 PM
911PERVY
911PERVY's Avatar
0 120 468 029 old number
0 120 468 125 new number
same part
Old 10-28-2013, 02:06 PM
JasonAndreas
Technical Guru
The Bosch Aftermarket Catalog is available online. You can even compare the specs between part numbers. Just enter the old number and then click on the replacement number.
Quick Reply: Alternator parts number - help
