replacing rod bolts without splitting the case.
Yes, it is possible (and common) to replace the rod bolts without splitting the case. However, you can only use a torque wrench to torque them, you cannot use a stretch gauge which (in my opinion) is the correct way to torque the rod bolts. Given that the engine was assembled using a torque wrench, there probably is no negative to doing using only the torque wrench method.
RL Technical Advisor
Yes, we do this all the time.
The rods get resized (rebushed if needed) and ARP bolts installed. We tighten the bolts to the specified stretch spec and measure the torque required to reach that value. If new bearings are to be installed, the rod journals are measured so the rods can be adjusted for correct bearing fitment.
Once re-installed back onto the crank, these are tightened to the measured torque value above to ensure proper tension & stretch on the bolts.
thanks Steve.
They charged me for splitting the case.
85 hours of labour for a reseal. 16000 dollars
The case was not split. Hopefully the rod bolts and bearings were actually replaced.
And it leaks like a sieve.
