964 Forum 1989-1994
GP White > 993 G50/21 LSD rebuild
Old 12-08-2013, 09:01 AM
ghhally
ghhally's Avatar
Default GP White > 993 G50/21 LSD rebuild
As a part of my GP White project, I decided to go for a 993 G50/21 gear box.
I was able to get a genuine G50/21 with LSD with known history. Based on this information I decided to only rebuild the LSD and clean the gearbox.
Here some detailed pics
Old 12-08-2013, 09:04 AM
ghhally
ghhally's Avatar
New friction plates and ramps were sourced from Matt @ Guard Transmission.
Meanwhile the case was glass bead blasted and enamel covered.
Everything was topped off with new chromated hard ware.
Old 12-08-2013, 11:19 AM
ras62
ras62's Avatar
Nice job! Looks like the new ramps have two different slip options, but why did you decide to change the ramps and did you go from 2 discs to 4?
Old 12-08-2013, 11:51 AM
Vandit
Vandit's Avatar
Work of art! I'd be tempted to just leave it on display rather than hiding it under the car.
Old 12-08-2013, 12:35 PM
ghhally
ghhally's Avatar
Number of discs wasn't changed, it's still 2x 2 discs.
As the car will see a lot of track time, I wanted to have more lock on accelaration.
Old 12-08-2013, 03:34 PM
Jacke2c
Formerly turbotwoshoes
Jacke2c's Avatar
Default What did you use to clean the gearbox?
Any chemicals/pressure wash?
Old 12-08-2013, 03:52 PM
ras62
ras62's Avatar
With this being an early C2 what arrangement have you got for the speedometer signal? I had to adjust the pickup ring when I intstalled a LSD but does the later box/diff use this arrangement?
Old 12-08-2013, 04:29 PM
ghhally
ghhally's Avatar
First with brake cleaner to take of all greasy stuff by hand, then glass bead blasting.
I'm going to take the signal from the ABS sensors as the later models
Old 12-08-2013, 06:39 PM
ras62
ras62's Avatar
So a new R52 and job done? The LSD makes a big difference to the way the car behaves, I was quite surprised after installation. Nice and stable under braking and in the recent slippy conditions the car was huge fun when getting aggressive with the throttle.
Old 12-09-2013, 06:33 AM
orp73
orp73's Avatar
The 993 G50/21/LSD gearbox conversion is a brilliant one, I did the same swap earlier this year, the gears are just perfect, I found it transformed the car the right ratio for every occasion plus a taller final drive
have fun
Old 12-09-2013, 09:54 AM
Geoffrey
Geoffrey's Avatar
The 50/80 markings on the ramps represent the amount of lockup during acceleation (50) and deceleration (80). The higher the number the more pressure is put on the plates to lock up the differential. 50/80 is very agressive for the street and are generally used in racing cars. The factory GT3 Cup cars come with 40/65 in either 4 or 8 plate versions depending on year.
Old 12-09-2013, 10:36 AM
HiWind
HiWind's Avatar
Love to see pics of perfectly restored and refreshed bits ... Very nice.
Can I ask ...
1.Who makes the original 993 LSD you have there? I need to check mine but invoice says 993 RS LSD
2. What's the downside on street to the 50/80 or 40/65?
3. What kind of enamel do you use re the (now beautiful) case?
Old 12-09-2013, 10:12 PM
SuperUser
SuperUser's Avatar
WOW, that looks better than new.
Quick Reply: GP White > 993 G50/21 LSD rebuild
