964 TT build - Need help with gearbox choice/ratios
#586
Everything is going smoothly. Might do a little cylinder head revision and looking at a better option instead of the 993 GT1 Evo cams.
Rebuild starts next week.
The only thing which is much harder than anticipated is finding a bigger chargecooler which fits the available space.
To be continued
To be continued
#587
You might want to have a try here: http://bellintercoolers.com
The company's founded by Corky Bell, author of "Maximum Boost" https://www.amazon.com/Maximum-Boost...rds=Corky+bell
I still must have a copy somewhere here in Amsterdam, if you want to I can look it up for you to borrow.
#588
Hi Thomas,
just by the way - the 993 GT1 engine was a water cooled 4V engine; 74,4 x 95,5 mm, eta 9:1.
The cam you are running is a GT 2 evo cam.
This is the latest Porsche Motorsport two valve turbo cam and already a very good profile.
On the more modern engine layouts, with higher static compression ratios, like in your case, you should react on the dynamic side with a cam profile that generates a suitable lift at TDC.
On this way you reduce detonation / pinging tendencies also.
Also a charged engine likes flow !
Look at it like you look on any normally aspirated engine.
With good ports and very important good valve seats you can go down with boost and have the healthier engine or you keep the boost level and gain mid pressure, torque and power as well.
Best regards,
Dirk
Best regards,
Dirk
#590
Ha! I wrote them an email yesterday!
I had already found the website through Google.
#593
The air ...
#594
Okay, it has been a while. But back to the original question why I started this thread. Boy, a lot happened since then! Haha
I'm back on the gearbox issue. The 964 turbo box was okay and took the beating without a problem but I always felt like the gearing was off. So I started wondering about a 993 6-speed, but those are so hard to find and can they take the power? But then it was suggested to me to look at GT3/GT2 gearboxes. A small change to the chassis and the cable control is actually not such a big issue if you get a really great transmission in return.
So this is what I am exploring now. I see the holy grail for me would be a nice G96/88 GT2 gearbox, which has almost the same ratios as the 993 G50/20!
But of course is stronger, has the H pattern and steel syncros.
But very hard to find. Much easier to find are the GT3 gearboxes, but those ratios are a bit shorter. And with my 850Nm this seems a bit silly. Am I right here? There is quite a difference in the ratios of the GT2 and the GT3, obviously Porsche did this with a reason.
So would it be sensible to change a GT3 gearbox to GT2 ratios?
Any feedback here would be greatly appreciated.
#595
Just found out the 996 Turbo G96/50 is exactly the same as the GT2 but without the oil cooling system but perhaps just needs a little modification for taking out the 4WD part?
These can be sourced new for a good price so this could be a nice solution.
#597
On another note, just picked up the last engine parts in Germany and finally we can start putting everything back together.
Very curious for the result of the new parts. The gorgeous new custom heads, rockers, pistons, conrods and cams.
Lower compression ratio of 8.5:1 and 4.0L
