964 TT build - Need help with gearbox choice/ratios
#616
Everybody has a different opinion is what is best, and you are the one that is paying and you don't want anybody testing new things out on your engine without you knowing.
Another thing is, I see a lot op people installing a gt3 oil pump in there high horse powered air-cooled cars. But what is the main reason for this, and are the benefits really there. Are there some numbers that show this or would someone tell there story.
Because we are still driving with the original oil pump and doesn't seem to have a lot of problems, that does not meen that i think that is is useless to install a gt3 pump. Instead, I am very curious to know why, does this pump boost reliability etc.
#618
Similar, more like a 993 gt2 evo engine. But someone with knowledge in that district is hard to find. Because every one nowadays knows is better than everybody.
Since that first transformation my own knowledge expanded and so did my wishes.
And this is the thing, if you want to go down the road of tuning you better be ready to dive into the rabbit hole. I knew that before hand. I had visited Singer and they just upped their prices from $200K to $400K after their initial sales so then I decided that I rather wanted a normal looking car (less conspicuous?) with similar features and perhaps a lot more power.
Something I could tour with and take to the track easily but still drive around town.
I am in love with the traditional 911 looks so the 964 was an easy choice.
So anyway, what I was trying to get to is that if you want a solid package you can lay down the dough with Singer or RUF or, for a third of the price do your own sh*t and deal with the learning curve. I'm not saying you will have a comparable end result, but you'll perhaps have something you are happy with as much. At least thats how it worked for me.
You are right that everybody seems to know better, but over time I've connected with people I like to work with and found advice from abroad. I've called people in LA with questions on oil strategy for my turbos which my mechanic in Amsterdam perfectly realised. Its not rocket science. Now I know some key people I trust and I use their advice when I make choices.
My engine failed after 50.000km but, to be honest, my mechanic already asked me several times to do a preventive rebuild before this happened. He knew how I was driving because he kept changing tires and brake pads...
But I was stubborn.
About the oil pump, I can tell you the 997GT3 pump has an extra scavenge inlet and I believe it has higher flow. TTP originally changed my 964 pump for a 930 turbo pump. But after the engine problem (conrod bearing failure) I wanted to change the pump and the radiators in the front to be sure everything is optimal and clean again. The new parts are too expensive to take any risk...
Damn...can't wait to get this car on the road again, really miss that crazy fun!
What a pleasure. Thats all worth it.
#619
Hi Colin, thanks for the offer. I'm not sure that is the right choice for me though. First of all I can get a new 996 turbo box probably for the same money and secondly I'm not sure if those ratios work for me. But this is the thing, its so hard to figure out what would be best in my situation.
My gripe with the current box is that it is a bit to long in the gearing, especially on track I think there is a lot to improve with better ratios.
#621
I'd have to look it up if you're really interested. PM me.
#623
Good luck with the build, it's all looking great!
#624
Current builder not happy, doesn't want to shim the cylinders.
The parts I bought are all installed up to the cylinders and pistons but the deck height is too small. Actually the piston is protruding slightly at TDC.
I found out that this could be solved easily by adding a shim to the bottom of the cylinder, raising the cylinder about 1mm to get 0.8mm squish.
But, my current builder is not comfortable with that so I'm bringing the whole engine to Germany tomorrow to have it assembled there. Good thing is that I know everything will be done to the highest specs.
Bad thing, I have to drive 2.5hrs to bring the damn engine.
#626
But yeah, far from ideal.
#627
Have to agree, I wouldn't even feel comfortable shimming a cylinder in a standard engine. A bit Heath Robinson after thought for an engine this bespoke.
You're changing engine builder half way through the build?
Was it an epiphany during one of your Yoga trances.
You must be feeling quite nervous about this engine. Wishing you all the best with it fella and hope to see the car in action soon.
#628
Yeah it sucks. It does not feel pleasant to change of course but I have no choice.
I'm not really sure why a shim would be bad, but I'll have a good chat when I'm in Germany. On my way right now!
