Oil line torque spec
Replaced my oil line from the filter to the case with a new OEM line and it is leakinng where it connects to the case. Old line didn't leak there and it's pretty bad. Anyone know the torque spec? Not that I can get a torque wrench to work but just would like to know how tight.
Technical Guru
Not really sure about the compression fittings on the lines themselves but...
Oil feed line adapter to case (M24) 90Nm (66ft-lbs)
Oil return line adapter to case (M22) 70Nm (52ft-lbs)
Thanks! I hope taking off and cleaning out threads and re tightening will do the trick. I want to be at Hershey for the swap meet Saturday.
