964 Forum 1989-1994
964 plug & play ECU
Old 08-03-2014, 04:02 AM
evoderby
evoderby's Avatar
Default 964 plug & play ECU
Don't know if this has been posted before, UK based Specialist Components (ex Lotus development) has just released a plug and play ECU kit for the 964.
32 Bit Microprocessor with 1Mb memory
Industry standard CANbus communications with Dashboards and Dataloggers
Bespoke SC micro USB-CAN dongle interface and Windows software
32 x 32 Fuel and Ignition Maps with user programmable breakpoints
1uS and 0.25deg Ignition Resolution
Wideband and Narrowband Lambda Control
Closed Loop Turbo Boost Control
Fully Sequential Fuel and Ignition Control
Powershift Capability
Automatic internal Barometric Pressure Compensation
Full Environmental Fuel and Ignition Corrections
Comes completely mapped and even includes air filter/induction tube @ 1650 GBP.
http://www.twinkam.co.uk/shop/articl...aid%3DSC300%26
Old 08-03-2014, 04:43 AM
Shamus964
Shamus964's Avatar
Interesting - I look forward to the opinions on this!
Old 08-03-2014, 05:32 AM
ALEX P
ALEX P's Avatar
Good find. I guess at around £2k you get ECU, software and MAF conversion it's not bad value either.
Who's going to be the first guinea pig then?
Old 08-03-2014, 05:54 AM
evoderby
evoderby's Avatar
An interesting option indeed, especially since it features closed loop wide band lambda control it should be a doddle to switch to larger (and more modern) injectors...
...as it has been pointed out by Colin many times that the standard injectors cause a severe restriction in the way our engines operate.
Old 08-03-2014, 06:21 AM
evoderby
evoderby's Avatar
Just to add, no personal experience with SC (only DTA and Emerald) but from what I hear the programming software is a bit less intuitive than others and requires a bit of a learning curve to master.
Old 08-03-2014, 07:41 PM
Ducks964
Ducks964's Avatar
Alexjc4 and I are going to try the VEMS plug and play ECU (with 55 pin connector). Alex is trialing on a nonaspirated model while I will be installing to manage my TPC supercharger. Both ECU's are in route and I will start a thread to document my install and tune (will also remove distributor and go with 2 bosch coil packs.
That unit does look nice though and appears to be thought out since it adds intake parts to remove the AFM.
Old 08-04-2014, 04:20 AM
robt964
robt964's Avatar
Hmmmmm.... I'll try and give them a call today to discuss the in/outs of this and report back.
Old 08-04-2014, 05:08 AM
robt964
robt964's Avatar
Couple of years old but a thread on the typhoon here:
http://tentenths.com/forum/showthread.php?t=119407
Old 08-06-2014, 03:09 AM
ST1972
ST1972's Avatar
Guys,
This kit is great and has transformed my 964.
Throttle response is instantaneous and the car is so much more fun to drive.
Highly recommended. Please see before and after power curves.....
Regards ST
Old 08-06-2014, 03:25 AM
RicardoD
RicardoD's Avatar
I see this is your first post. Can you tell us more about yourself, your car, and your decision to go with this new ECU for your car. Are you in any way affiliated with Specialist Components?
Old 08-06-2014, 05:45 AM
PhatPhlatSix
PhatPhlatSix's Avatar
Does anyone have a before and after power curve for a SW chip on a stock engine, to compare with ST1972's curves?
A 3rd party ECU will give a better ability to tune the engine mapping for a modded engine, but it should be no better than a good chip for a stock engine. This goes for the WOT power curve - driveability may be improved with modern electronics...
Old 08-06-2014, 11:57 AM
evoderby
evoderby's Avatar
Originally Posted by ST1972
Guys,
Regards ST
Thanks for posting these dyno sheets, a good 11.5% increase in power....interesting to see a base number for a stock engine that is below 250Bhp for once.
As others have asked, can you share some more detail on your car i.e. Mileage, type of exhaust/cat and what type of dyno measurements were taken on (rolling road vs engine dyno)? Also be interested to know if all dashboard warning lights are still operational and functioning as the should (no permanent check engine lights burning in front of you).
Rgds
Harald
Old 08-07-2014, 09:02 AM
ST1972
ST1972's Avatar
Hi Guys,
My car is a Stock 1990 C2 (US) Californian spec vehicle. It was my daily driver & has 190K miles on the clock!
Exhaust - Cat bypass and G pipe fitted, standard Porsche rear centre muffler.
The car was set up on the APT Performance 4 wheel rolling road in Lenwade Norfolk UK.
No warning lights. AC / HVAC and the cruise control function as required.
I know the guys well at Specialist Components we are all ex Lotus colleagues.
Hope this helps…..
Cheers ST
Old 08-07-2014, 09:57 AM
robt964
robt964's Avatar
I've been trying to call them multiple times these past few days and regardless of time I get nothing but an engaged tone. That doesn't usually bode well.
Old 08-07-2014, 10:21 AM
PhatPhlatSix
Hi Guys,
Hope this helps…..
Cheers ST
Was the 'before' power curve done before or after the Cat Bypass and Gpipe mods?
Quick Reply: 964 plug & play ECU
