964 Forum 1989-1994
Heater bypass - definitive wiring solution
Old 09-13-2014, 06:11 PM
anto1150
anto1150's Avatar
Hi all,
I was a little tired to see that single red cable hanging around my engine bay... Just didn't look right...!
So i spent some time looking for a better way of getting a switched lead...and i found it!
Remove the green relay; now remove the relay support (2 8mm bolts). Underneath the green relay there's a violet (maybe green/yellow on early cars) wire: that's it! With the help of a tap-in squeeze connector, connect a wire to that violet one (I chose yellow because it usually stands for "switched +").
Now terminate the new wire with an appropriate spade, put everything back togather and you're done! Simple, effective and clear.
Ciao
Jaime_911 (08-08-2022)
Old 09-13-2014, 06:38 PM
crg53
crg53's Avatar
Good one. Did you put a fuse in between.
Old 09-13-2014, 07:01 PM
anto1150
anto1150's Avatar
I disn't, beause i'm pretty sure that violet line is already protected....but you can add a small fuse if you feel safer...
The violet wire is 0,5, so it's ment to carry a very little amount of current (means safe to me...)
Old 02-07-2015, 11:36 PM
racemor
racemor's Avatar
Hey Anto, what gauge wire did you use?
Old 02-08-2015, 08:59 AM
anto1150
anto1150's Avatar
Racemor, that wire won't carry any significant amount of current, so no need to use a particular size. Just something strong enough
Old 02-08-2015, 10:39 AM
ThomasC2
ThomasC2's Avatar
I tried this earlier today but my fans shut down. I put my old set up back (cross connect + and ground) and then they worked again.
Possibly that the connector hasn't cut through the purple wire but I think so. My yellow wire looks like the same size as yours.
Old 02-08-2015, 11:26 AM
anto1150
anto1150's Avatar
Thomas, could be... connectors aren't 100% reliable. I'd check with a multimeter, before reassebling.
Old 02-08-2015, 11:41 AM
ThomasC2
ThomasC2's Avatar
Yeah, that struck me to. What should the mulitmeter read with ignition on?
Thomas
Old 02-08-2015, 06:42 PM
anto1150
anto1150's Avatar
12 V; 0 when ignition is off.
Ciao
Old 02-09-2015, 03:44 AM
ToreB
ToreB's Avatar
Good job. The violet wire is Terminal X, it's fused, and this modification will only introduce a very small current draw, if any. It connects to the Climate Control Unit rear fan feedback signal input.
Cheers,
Tore
The following 2 users liked this post by ToreB:
C2_trga (06-08-2021), kos11-12 (09-13-2022)
Old 02-09-2015, 04:07 AM
ThomasC2
ThomasC2's Avatar
OK, I had 0V with ignition on (all warning lights on, not the engine running). So I have to check the connector again.
Thanks,
Thomas
Old 02-09-2015, 12:29 PM
DobermanDad
DobermanDad's Avatar
So this is working for you guys?
I haven't done anything to mine yet after the RS bypass duct was added and my heater works fine. I feel like I should even mess.
I was gonna do the wire mod from the coil, until I saw this, but it seems like I don't even need to do either.
Old 02-09-2015, 03:32 PM
ThomasC2
ThomasC2's Avatar
Now it works! The blade in the connector had pushed the wire outwards instead of through it. 12V it is!
Better than my old cross jumper fix? i don't know, but probably.
Thomas
Old 02-10-2015, 04:14 AM
anto1150
anto1150's Avatar
Tore,
thanks for the feedback
Old 02-11-2015, 04:05 AM
Bertrand
Bertrand's Avatar
I just checked the schematics: On models 1989 and 1989 only that wire should be Green/Yellow. It's violet on all models 1990-1993.
Quick Reply: Heater bypass - definitive wiring solution
