964 Forum 1989-1994
idle issues
Old 09-25-2014, 02:09 PM
Richard Curtis
Richard Curtis's Avatar
StopLookGo: Always check the simple things first. Before you do anything else, disconnect the battery cables and clean the connections, both the cable ends and the battery post, even if new. Also disconnect the negative-cable-to-body and clean that connection throughly (both the cable end and where it connects to the body).
Old 09-28-2014, 06:15 AM
StopLookGo
StopLookGo's Avatar
Thanks for the replies. Another update. I tested the idle switch with the ignition in the on position and pushed the throttle cable down, there was an audible click sound but it wasn't coming from what I believe to be the microswitch. I tested with the ignition off and tested again and the sound was also present when I depressed the cable.
I've also checked the battery cables. All terminals and body connections are clean and tight.
A new development. I had to give it a little throttle to start her today. 2 out of 5 times. When I was looking around the engine bay I noticed the small FPR vacuum hose had popped out one end. Fixing it back was a chore as the rubber connector is now slightly shorter.
As it stands I believe i need a new FPR, FPR hose and, for peace of mind, an O2 sensor. Anyone have part numbers handy?
update - still had to give it a bit of throttle to start the car even after fixing the vacuum hose unfortunately.
Old 09-28-2014, 01:22 PM
RicardoD
RicardoD's Avatar
Buy your Bosch Oxygen sensor from Amazon if you are in the USA
http://www.amazon.com/gp/product/B000BZI34E/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1 http://www.amazon.com/gp/product/B000BZI34E/ref=oh_aui_detailpage_o01_s00?ie=UTF8&psc=1
and I use Sunset Porsche for the rest of the OEM parts
Old 09-28-2014, 09:25 PM
StopLookGo
StopLookGo's Avatar
that seems to be a very good deal. Unfortunately I am not Stateside. I'm in South East Asia so my options are quite limited.
Old 09-30-2014, 08:07 PM
StopLookGo
StopLookGo's Avatar
Since I'm getting a new FPR, I was wondering if I would benefit from getting an aftermarket FPR? I do eventually plan to get a SW chip and cat delete.
Old 10-28-2014, 04:12 AM
Mark Brook
Mark Brook's Avatar
Did you find the cause of your issues?
Old 10-29-2014, 01:56 AM
StopLookGo
StopLookGo's Avatar
Unfortunately no. I placed an order for a new FPR from Sunset but it hasn't been shipped yet. I'm hoping that will solve the problem.
Quick Reply: idle issues
