Spoiler vs Central Warning Light
I have removed the stock rear spoiler and engine cover replacing with a GT spoiler tail section.
My issue now is the Central warning light keeps coming on along with the rear spoiler warning light. Does anyone know what needs to be disconnected to stop the warning lights. Is it as simple as pulling the fuse or do I need to pull the spoiler control module?
This is from memory, so bear with me.
There are two switches on the spoiler mechanism, one is switched when the spoiler is full down, the other switches when the spoiler is up. If you jumper the up position switch, the car should be totally happy.
Here's the tech article on it - you put a jumper wire into the female spoiler connector at the back of the car. No more light!
http://www.pelicanparts.com/techarti..._rear_wing.htm
