964 Forum 1989-1994
dual exhaust?
Old 04-02-2015, 12:07 AM
tcsracing1
tcsracing1's Avatar
Default dual exhaust?
Anybody ever bother installing dual exhaust on their 964?
What is the most desirable exhaust for the 964 nowadays?
Old 04-02-2015, 06:15 AM
banzaisan
banzaisan's Avatar
I just bought the FVD Brombacher exhaust system. Search under YouTube to hear the sound of the exhaust. I had a hard time spending $5K but after seeing Larry Ammo's engine rebuild I was hooked.
Old 04-02-2015, 10:08 AM
911Jetta
911Jetta's Avatar
Originally Posted by tcsracing1
...What is the most desirable exhaust for the 964 nowadays?
For SANE $$$, great sound, less weight and similar horsepower results, it's hard to beat: a cat bypass with a primary muffler bypass. The gold standard.
$200-300 for a cat bypass
$200 for a primary bypass
Make sure your airbox is drilled too.
With that set up, you're not part of a "product development" team, and there's no drone, bumper mods or heat problems....
Old 04-02-2015, 10:14 AM
breljohn
breljohn's Avatar
Do you happen to know how many db that setup makes?
Some tracks have noise regulation and I really don't wanna get caught :-)
Old 04-02-2015, 10:27 AM
LPMM
LPMM's Avatar
^^^ This! The PO put dual exhaust on mine and if I were to change the exhaust today, I would definitely not go that route. I have no heat issues, but you'll deal with everything else Udo mentioned.
^^^ And this or huge bonus points for a functioning GT3RS center exhaust.
Old 04-02-2015, 10:31 AM
911Jetta
911Jetta's Avatar
Sorry OP, just saw that I missed the "dual" part in your post.... sorry about that. Carry on.
I don't know the db, but it should comfortably pass. It's an aggressive sound, but in no way obnoxious or tiring...
A cat bypass, with a secondary exhaust bypass (also another great sound) is a notch louder and I have read a couple posts of people switching to a primary bypass to reduce db a bit.
Originally Posted by LPMM
...functioning GT3RS center exhaust.
+1
Old 04-02-2015, 10:32 AM
warmfuzzies
warmfuzzies's Avatar
I'm on a Dansk dual, 100 cell cat, custom inlet and filter, with no secondary.
old school at low revs, more of a snarl when at high revs and coming off the throttle.
Kevin
Old 04-02-2015, 03:25 PM
breljohn
breljohn's Avatar
+1
Does this require any other adjustment (ECU for example)?
Old 04-02-2015, 09:53 PM
911Jetta
911Jetta's Avatar
I have a 93 oct. Steve Wong chip, so my system eventually grew into this current setting:
I installed a primary bypass = 15+ lb. weight savimgs and great sound.
I bought a 93 Steve Wong chip = Car idled perfectly and had had more urge sub 4,000. Soild idle!!!
Installed a Fabspeed cat bypass = more weight savings, awesome mechanical sound, less heat, +++ throttle response. Only a little more noise, but it's so good everyone around the car smiles (and coughs a bit too =)
Old 04-02-2015, 10:07 PM
jellonailer
jellonailer's Avatar
I have this:
964 Dual Outlet Maxflo Muffler with Oval 4.5" tips
964 Catbypass pipe with O2 sensor bolt-on
Wong Chip
LWFW
Sweet
Old 04-03-2015, 05:03 AM
koenig_roland
koenig_roland's Avatar
i`ve this exhaust (with cat and a little bit of heat) from a german supplier - exclusively made for my mechanic - and it is great. Great sound, great power (with other mods).
friends of mine have the M&M (brombacher/fvd) system on their cars (single and dual outlet) and it is louder but not better :-)
I would go for a good, full header system....
Old 04-03-2015, 04:37 PM
tcsracing1
tcsracing1's Avatar
Interesting.
Based on the diagram of a stock exhaust I can see what you are talking about.
So bypass the cat, and bypass the final muffler leaving only the intermediate muffler stock.
Any issues with deleteing the cat? Error codes?
(I have Fister II on my 993 and it sounds they way the factory should have made it. I would like the same type of subtle sound for the 964.
So should i delete cat or custom cell cat? For the two mufflers, should i delete any of them or replace them with custom?)
Old 04-03-2015, 06:45 PM
LPMM
LPMM's Avatar
The bypass Udo mentioned is to replace #6 & #8 in your pic. No issues with a cat bypass except for reported foul exhaust smell by some folks.
Old 04-03-2015, 07:36 PM
JJJMCD
JJJMCD's Avatar
Sport cat is much more livable for a street car than cat delete. Otherwise, you'll be breathing unburned hydrocarbons at every stoplight (think about how it smells to drive behind an old beater taxicab belching blue smoke). You'll also smell of fuel/exhaust after even the shortest drive. It's particularly obnoxious if you have a cab or targa. You can also forget about the significant other joining you for rides or allowing you to bring the kids.
Old 04-03-2015, 07:37 PM
tcsracing1
tcsracing1's Avatar
thanks for the clarification.
So what muffler is best to bi-pass? the Intermediate or final?
Quick Reply: dual exhaust?
