Convert C 4 box to C2
#182
Hi @koenig_roland - thanks - ok you mean the Turbo look thanks- are the drive shafts the same length (despite the CVS being smaller)?
I guess I'll have to do a test fit before I order the shafts .. they have the sexy RSR cooling fins
#183
hi.
i meant the flanges at the box itself. The driveshaft in an WTL should be longer, but the flange at a WTL-G64 box should be (i was told it is and there are special flanges in the PET for the WTL) the G50 sized flanges... With those flanges in a G64 equiped narrow car, you should be able to drive the normal G50 driveshafts... I did some research in this dircetion when i had the problems with my car blowing driveshafts constantly... But i found an other solution for that issue :-)
#184
ok seems the shaft is 100mm longer than the TIP shaft .. what was your solution @koenig_roland - Titanium or CF shafts ala @Robert Linton ??!!
I have new hollow shafts but they are not much lighter than the stock shafts (though they should be stronger/slightly more flexible) and there's some weight saving on the finning of the CV but not huge
#185
The only way to find out would be to ask a prts dealer to compare the two parts refs.
Anyway, replacing the shafts doesn't mean you have to replace the flanges, if they are the same diameter : 108mm
#186
